VEHICLE INFORMATION
Merchandising Model : 1YY37 -2002 CORVETTE Z06 Warranty Start Date : 07/14/2002
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : WEST CHEVROLET, INC.
3450 AIRPORT HWY
ALCOA , TN 37701-3235
(865) 970-9378
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
10/26/2004 342810 # N6606 - WIRING AND/OR CONNECTOR - FUEL SYSTEM - REPAIR OR REPLACE 13650 miles
10/21/2004 342519 # J6400 - VALVE, EVAPORATIVE EMISSION CANISTER PURGE CONTROL SOLENOI 13393 miles
08/26/2004 322791 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 12612 miles
08/26/2004 322791 # J6400 - VALVE, EVAPORATIVE EMISSION CANISTER PURGE CONTROL SOLENOI 12612 miles
08/26/2004 322791 # N4920 - MODULE, LOCAL INTERFACE UNIT - DOOR - RIGHT - REPLACE 12612 miles
05/28/2004 318323 # F2005 - COVER AND/OR GASKET, DIFFERENTIAL - REAR DIFFERENTIAL - LE 11236 miles
11/07/2002 044978 # Z8014 - ROADSIDE SERVICE (BATTERY/JUMP START) 2800 miles
09/09/2002 924703 # Z8014 - ROADSIDE SERVICE (BATTERY/JUMP START) 1500 miles
03/22/2002 A26211 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1614 kg (3559 lb) Order Number : DZXRQ2
Build Date : 03/22/2002 Build Plant : 125Y
OPTION CODES
AAB - MEMORY PACKAGE AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AR9 - BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES BGR - BOWLING GREEN PLANT
B84 - BODY SIDE MOLDINGS CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV DD8 - OSRV
DL5 - ROADSIDE SERVICE INFORMATION DECAL FE4 - RIDE & HANDLING SUSPENSION SYSTEM
FE9 - 50-STATE LOW EMISSION VEHICLE GU6 - REAR AXLE 3.42 RATIO
IP4 - TRIM INTERIOR DESIGN - AR9 JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 - 110 AMP GENERATOR LS6 - 5.7L LITER SFI V8 - 405HP
MN6 - 6-SPEED MANUAL TRANSMISSION M12 - 6-SPEED MANUAL TRANSMISSION WITH OVERDRIVE
NF7 - FEDERAL EMISSION SYSTEM NLEV NK4 - LEATHER WRAPPED STEERING WHEEL
P12 - CAST ALUMINUM WHEEL SLM - STOCK ORDERS
UN0 - AM/FM STEREO W/CD PLAYER UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U52 - ELECTRONIC INSTRUMENTATION U73 - FIXED MAST ANTENNA
VM3 - CONSUMER INFORMATION LABEL V49 - LICENSE PLATE FRAME
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XFW - FRONT TIRE-P265/40R17
YFU - REAR TIRE-P295/35R18 1SA - CORVETTE Z06 BASE EQUIPMENT GROUP
12U - QUICKSILVER METALLIC 19I - BLACK INTERIOR TRIM
194 - Z06 INTERIOR - BLACK
I wouldn't worry about it at all. The repairs were done by an authorized dealer and it's been almost 3 years since that recurring problem. The Carfax is also clean on the car.(Take that for what its worth) 3 owners etc.
Battery charging is a common problem. These cars lose their juice when they sit for awhile. The diff seal is common. I had to do it to my 2002. The rest is petty stuff. No sign it's a lemon. If the current miles are reasonable and the price is reasonable, GO FOR IT!
