C5 differences year by year
Old Jun 4, 2007 | 11:55 PM
zzzzzeke's Avatar
zzzzzeke
Default C5 differences year by year
Is there a nice chart/breakdown of the differences between 97-04's?
I've done some searching around the forum, with not much for luck.
I specifically looking for info on coupes, but convertible or Z06 data could be nice too.
Any recommendations are welcome too...I've been looking at coupes with the dual roof option and Z-51 packages so far.
Sorry if this is a repost or a n00b question, but thanks in advance!
Old Jun 5, 2007 | 12:03 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Here is a listing that was posted by a forum member a while back. There may be more differences, but this is a good start. Note, not all of these are visual differences that you can easily see.
1997
* Completely new, redesigned Corvette. Base (FE1) and Z51 (FE3) suspension packages.
* All Z51 cars include: Power Steering Cooler
* 97-00 C5 LS1's produce 345 HP @ 5600 RPM and 350 Ft Lbs of torque @ 4400 RPM.
1998
* Convertible becomes available
* Active Handling becomes available late in year
* The two slots of a 1998 (and possibly late 1997s) curve toward the rear at the bottom. (versus straight down)
1999
* 26# injectors substituted for 28#
* Fuel pump revised to reduce noise
* FRC "Fixed Roof Coupe" aka the hardtop, becomes available. All FRC's are MN6 (6-speed) cars with the Z51 suspension package, and are about 60lbs lighter than coupes.
* HUD introduced
* Only one line in driver's side fuel rail cover (no fuel return line?)
* Power telescoping wheel becomes an option
* Steering hardware changed to combat wandering
* Door sill trim plates added
2000
* Millennium Yellow available
* "Thin Spoke" versus "wagon wheel" design wheels become standard.
* Pup cats added to all models for LEV emissions requirements (5hp loss relative to 97-99)
* Steel swaybar endlinks instead of plastic on Z51 equipped cars
* Z51 swaybar diameters grow (25.4/21.7 to 28.6/21.7 to 28.6/23.6 (note: new rear same as Z06)
* No keyhole on passenger side doorhandle
* Passenger airbag 'off' switch added to console (light by TC/AH button)
2001
* Return to 28# injectors for all models.
* Second Generation Active Handling
* Nassau Blue discontinued
* Alternator 'clutch' pulley added on A4 cars
* New soundproofing + foam in all cars
* Smaller keyfob
* Electrochromic dimming rearview and driver's mirrors
* Lighter AGM battery
* Thickness + Material in Convertible change
* Chrome exhaust tips for coupe + Convertible
* 85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
* LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
* All Corvettes now have the LS6 intake manifold
* All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
* LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
* Hardtop/FRC discontinued
* Stronger synchros in all transmissions
* Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
* Metal valvestem caps (late year)
* Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in diameter from 55 to 63 mm.
* Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
* Introduction of the Z06, which has as differences:
* Hardtop body style
* Rear brake ducting
* Screened inlets on front fascia, without foglights
* F1 Supercar tires 265-17 front, 295-18 rear, on 17x9.5 and 18x10.5 (one inch wider, respectively
* New LS6 top-end with new style head design (10.5:1 compression, 64cc chamber), LS6 cam (0.525/0.525, 204/211 on 116) - 385hp
* M12 transmission with shorter gearing (1-2-3 analagous to MN6 with 3.90 rear diff
* Titanium exhaust system
* Lightweight windshield
* New, stronger clutch with redesigned master + slave cylinder
* Stronger rear differential (shotpeened ring gear)
* Red brake calipers (otherwise identical)
* Transmission overtemp warning light on DIC
* 6500 redline gauges with special checkering + Z06 font
* Redesigned PCV system to help combat oil burning
* Red LS6 Fuel Rail Covers (FRC's)
* FE4 Z06 suspension - uprated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51)
2002
* Z06 Changes:
* Z06 LS6 cam changed to: 0.551/0.547, 204/218 on 117.5
* Less restrictive intake airbox lid
* Descreened MAF
* Removal of pup-cats (total with changes = 405hp)
* Z06 shocks revised with less rebound for better launching
* Z06 brake pads revised for better stopping (generate more dust)
* Lighter, sodium filled valves w/ stronger valve springs
* Higher tension rings installed to prevent oil burning problems
* Slight piston redesign *
* Clutch strength upgraded.
* HUD available on Z06 (not avail '01 model year)
* Wheel supplier changed to Speedline, moved from forged to cast. Weight nearly identical
* Electron Blue color offered
* Steel endlinks changed to aluminum
2003
* Late model-year new fuel system design from C6's
2004
* Z06 shocks further refined. Accompanying upper front control arm bushing, and rear swaybar bushing changes.
BTW - I found this using the search feature.....
mtt0436's Avatar
mtt0436
St. Jude Donor '08
I'm a newbee, N00b, etc. too. I think it's been asked but ya never know until you ask. And hopefully it will be a gentle response without any put downs. Besides, I want to know too.......Finish your profile........
Old Jun 5, 2007 | 12:05 AM
mtt0436's Avatar
mtt0436
St. Jude Donor '08
You're fast blacksedan87!
Old Jun 5, 2007 | 12:07 AM
blacksedan87
Can you imagine that I typed all of that?
Old Jun 5, 2007 | 12:10 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Her is a great website: http://www.corvetteactioncenter.com/specs/index.html
Old Jun 5, 2007 | 01:02 AM
BATM4N's Avatar
BATM4N
Hey Randy, I thought you weren't going to help out on these threads anymore let alone type all that You must of been the top of your class at Mavis Beacon Univ. Glad to see you back in full force helping out a bro
Old Jun 5, 2007 | 01:07 AM
blacksedan87
I took a vacation from work and the forum, and came back with a new attitude. It's all good my friend!
Old Jun 5, 2007 | 01:58 AM
2KFRC5's Avatar
2KFRC5
Correcting a couple of discrepancies. Don't know about other years.
2000
* Pup cats added to all models for LEV emissions requirements (5hp loss relative to 97-99)2000 Corvette LEV-compliant in states requiring California emissions. Different cam in 2000 engine, I believe compensated for the 5hp loss.
* Steel swaybar endlinks instead of plastic on Z51 equipped cars Rears were still plastic
* Passenger airbag 'off' switch added to console (light by TC/AH button) Added late model year
Old Jun 5, 2007 | 11:59 AM
jovette's Avatar
jovette
2000
Yep, so the 2000 vettes delivered to non LEV states, like mine, actually had 350 hp, since they still got the bigger camshaft (.500 lift) but did not have the pup cats installed.
Old Jun 5, 2007 | 12:40 PM
ytwokc5's Avatar
ytwokc5
You forgot - 2000 - Dark Bowling Green Metallic available!
Old Jun 10, 2007 | 10:56 PM
zzzzzeke's Avatar
zzzzzeke
well thanks for the info guys! I went out and bought a GM certified torch red 2004 coupe with 16K. I think I'm hooked!
Old Jun 10, 2007 | 10:59 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Congrats on your buy and where are the pictures
Old Jun 10, 2007 | 11:07 PM
zzzzzeke's Avatar
zzzzzeke
just a few taken so far....been too busy driving it!
To C5 differences year by year
