WTH? Car wont crank sometimes?
Old Jun 5, 2007 | 09:54 AM
Zonify's Avatar
Zonify
Default WTH? Car wont crank sometimes?
Now this was an intermittent problem like 1.5 years ago and I think it may be starting again...
Basically when I try to crank my car all electronics turn on fine, but the car wont crank. So I wait 5 or so mins and all of a sudden it always cranks fine. This has happened to me twice in the past 3 weeks now, and around 1.5 yrs ago would happen every 3-4 days or so for a good 2 months straight and just stopped...
Any ideas? I have a Yellow Top Optima battery.
Old Jun 5, 2007 | 10:14 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
It's probably not the battery if the other electronics work.
There are a lot of possibilities. Might want to look at faulty ignition switch or problem with starter or starter wiring.
Old Jun 5, 2007 | 10:17 AM
Hatepylons's Avatar
Hatepylons
Check the continuity of the neutral safety switch - easiest thing to check and will result in what your car refusing to crank.
Old Jun 5, 2007 | 10:34 AM
bighank's Avatar
bighank
Default won't crank
Mine was a dead spot in the starter. Replaced it and no more no crank. Have to lower exhaust though. Ain't vettes FUN BIGHANK
Old Jun 5, 2007 | 10:36 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old Jun 5, 2007 | 01:15 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I had the same thing and my gremlin was inside the key cylinder... the sensor for my resistor stopped working... They replaced the whole cylinder and fixed the problem.
But I would also look at the resistor in the key and make sure it's not damaged or corroded.
Old Jun 5, 2007 | 02:05 PM
VetteLag00's Avatar
VetteLag00
Similar to a problem I've had. Sounds nuts but did you shut off your car, leave the door unlocked, and try to start it again? I have been making sure to the lock the door after I shut the car off, even if the roof is off and I am in a safe place for a short time. Then I unlock it before starting again I thought it had something to do with the security system. Whatever it was this method has not failed me and I've been using it for months.
To WTH? Car wont crank sometimes?
