tps
Old Jun 5, 2007 | 07:47 PM
ironmike55047's Avatar
ironmike55047
5th Gear
Default tps
Do you need the tps & what happens if you dont insall them.
Old Jun 5, 2007 | 08:06 PM
wamara's Avatar
wamara
Cruise-In II Veteran
You don't need them in the sense that you can still drive the car without them, but they are a safety feature if you are driving on runflats. If you don't have them, you will continually get warning messages on your DIC, which you can remove (but only temporarily) by hitting the reset button. If your car is an '01+, you can deprogram the BCM with a Tech II to deactivate the sensor receivers.
