LONG TUBE Header install question
Old Jun 6, 2007 | 11:37 AM
DGW's Avatar
DGW
Default LONG TUBE Header install question
I am installing lg long tubes this weekend, this might be a long shot but is there anyway to do it with jack stands in my garage or do you have to have a lift?
Old Jun 6, 2007 | 11:45 AM
the_teapot's Avatar
the_teapot
St. Jude Donor '10
Do a search on header install & you should find some great info, including pix. I also found step-by-step instruction on another site, I think it was ls1tech.com. I've read that you can do it on jack stands - tricky but can be done. Haven't pulled the trigger on buying LT headers myself... yet. I'm sure others will chime in with some advice. Good luck on the install & keep us posted on how it goes!
Old Jun 6, 2007 | 11:49 AM
Anthony01's Avatar
Anthony01
I've done 3 C5 and 1 C6 installs on my garage floor. I put down 2x12 down in front w/ Rino Ramps on those, and jack stands in the rear crossmemeber.
On C5 you will have to jack up the front to lift the body when you put in the driver side from underneath. Pass. goes in from top.
Old Jun 6, 2007 | 11:51 AM
Rickyh93's Avatar
Rickyh93
I've installed a set on my friends vette with 4 jack stands. They were set as high as they would go but I tried shaking the car and it was very stable. We did lower it down a little when we started it up and crawled under it to check for exhaust leaks.
Hopefully I will installing mine next week when I get back in town.
Old Jun 6, 2007 | 11:58 AM
rws.1's Avatar
rws.1
here's the link to the LG header install instructions done with Rhino ramps and jackstands
http://www.ls1howto.com/index.php?article=29
To LONG TUBE Header install question
