Need help adding freon to a/c
It's a 1998. I know it's R134 because the Blazers changed in 97. Plus, I know what an R12 valve looks like.
When you say the connector won't fit on the high side, do you mean it can't possibly even be forced on? Is it that much larger than the low side?
The service guy asked me what year my car was I said 98, he said I need R12,
-no it takes 134a
oh, phht, that's not freon
-well it's the refrigerant
phht, no no, that's just..just.... pause...that's not freon.
-well, do you carry it?
no you can't just buy it anymore, they have it in the shop (garage part of Cnd Tire)
-wonder if they would refill it for me
well....I guess they COULD refill it for you, not sure how good that is for the environment, you need to seal the leak, I mean I guess it depends how you are morally about letting it leak into the envirnment
thanks, cya.So i drove all the way out to crappy tire for nothing AND i got a lecture from this crusader.
Meanwhile it's available to 300 million americans just like that.
I'm sure denying me a bottle makes all the difference.
Well, I got it on about halfway, like I said, but it wouldn't slide all the way down. Then, I made a fist around it so the base of my palm was right at the connector, and I squeezed really hard until I was afraid it might break. And it still didn't slide any further. There was no impediment or dirt. So. I haven't gone and tried the other one until I'm certain which one is correct.
Thanks again.
Pretty much follow what sneakleman says, in post 10. The only thing I would add, buy a meat thermometer (they are cheap), insert it in the center air vent, start car turn a/c on max, turn control to 60 deg, close windows. As you are charging system, periodically check thermometer. As system charges, air coming out of the vent should cool to 40-44 deg. That's what you want. Quit charging at that point.
I have a '98 coupe. Both fittings have black caps. I just finished rechaging mine. If your system was empty, you may want to add about 1 and 1/2 oz of refrigerant oil before you put in the 134A. It comes in two oz cans. After I completed charging the system and disconnected the hose, I noticed a very slight bubbling around the Schrader valve (looks like the little valve inside a tire stem) and snugged it up. Check yours and if necessary you can buy the tool for it or use a needlenose pliers. Just don't exert any great pressure on it. I kinda think that's where my slooow leak was coming from.
Cheers and good luck.
See, there's a perfect example of what you get on the forum here..... good sound advice/information from more than one person. This is great because there are things I missed that he picked up on, the thermometer, the schader valve bubble, all things I usually do and look for that I forgot to post. Said it before, I'll say it again.....Gotta love this place! The Best of Corvette for Corvette Enthusiasts
Have someone that knows HVAC to help you, if you have a leak you need to repair it or you will be recharging all the time and lossing a little oil with the leak and damage the compresser.
R-12 will not go bad, make sure you don't mix refrigents.
My Old guages were FINE but lacked the NEW Push on (and make sure they engage) fittings on the R134a systems. Would have cost me MORE to try and find conversion parts for my old hoses so I went to Harbor Freight and bought a NEW guage set with the new fittings and even a plastic carrying case for either $39 or $49. The R134a is EXHORBANTLY PRICED at the local auto stores so I bought a CASE OF 12 at SAMs. If you need more than a can this is probably the way to go. If you have more than one car with A/C this is the way to go. FREON DOESN'T GO BAD. I have several cans of R-12 that belongs in the Smithsonian. Also if you have a freon LEAK adding more freon won't fix that and it will leak out again. Most leaks are at the connection points where there are usually SPECIAL o-rings as sealents.
Ordinary o-rings will deteriorate from the freon and refrigerant oil going thru the lines. Air in the system is not GOOD for two reasons:
1. It takes up SPACE and therefore is not compressed as well as the freon giving you LESS COOLING.
2. If lines are LEFT OPEN for a good length of time MOISTURE can get into the system and this can cause corrosion.
You CAN make a VACUUM pump out of an OLD REFRIGERATOR COMPRESSOR, some rubber hose and a brass fitting that will connect to the female connector on a guage and hose set.
I made one about 20 years ago from an old compressor and it works great today even though I haven't run any freon thru it since I made the VACUUM drawdown system. When using it you run the pump continuously for about 1/2 hour and then shut it off. You should see about 28 inches of vacuum on the guage. IT SHOULD KEEP THIS VACUUM for at least 15 minutes or so with the refrigerator compressor OFF and if it DOESN'T it means you have a LEAK in the system. Fix this before you charge the system or you are just wasting freon and it will leak out and get you back to no A/C
http://cgi.ebay.com/ebaymotors/R134a...QQcmdZViewItem hope this helps.
But before I do any of that I'm taking my car into the shop monday to have a test done, just to make sure it's not the compressor.(I thought I had this done but I never did, I only had a pressure test done, no follow up) If it's a cheaper fix like a hose or somthing I'll do that first.
Also, didn't R-12 have a screw-type connector? If true, that's a good way to tell which system you have. I used to push that into the A/C all the time on the older beaters I had. Still have half a tank (10-15 lbs) of R-12, but they say it goes bad in 1-2 years. I'm hanging on to it, if anyone wants it.
Thanks for the help.
