[Z06] Love Stock Shifter?
I had to open my tranny due to a 'stuck in 4th' recurring problem(while I had oem shifter installed)
So, outside of changing to billet keys and bronze shift fork pads, I reduced the tension on the spring loaded ball detent assembly as well as the other ball detent on the upper side of the tranny, and it shifts like butter, even with the short shifter cut down.
Less than 2" travel from 3rd to 4th (measured at top of shifter ****). Even reverse is a piece of cake.
Worth the effort if the tranny has to come out anyhow...
