Every Time I Fill Up My Z06, The Gas Gauge Is A Couple Notches From The "f"(full) On The Gauge. I Know The Fuel Tank Is Full But For Some Reason The Gas Guage Never Goes On The "f"(full),
What Can This Be????
Have You Ever Experienced This Prob???
What Is The Solution???
I'd make sure I'm using quality gas and also run a bottle of Chevron Techron Fuel System cleaner through it. A lot of cars have problems with "junk" building up around the sensor and the sensor not reading correctly on the dash.
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
And now it's improved!
"SAN RAMON, Calif. -- Chevron Products Company, a leading provider of engine oils, lubricants, coolants and related services, today introduced a new addition to its industry-leading family of fuel additives. TECHRON(R) Concentrate Plus Fuel System Cleaner, a reformulated version of Chevron's TECHRON(R) Concentrate, is the only fuel additive that provides both unbeatable engine deposit control and protection against harmful sulfurs that can cause fuel gauge sensors to malfunction."
Thank You Very Much!!!
Unfortunately a common problem. The techron worked for me most of the time. Now I use Chevron gas all the time and no issues. As soon as I would use Shell gas, the gauge would completely fail until I nearly emptied the tank and put Chevron (with techron) back in.
The same exact things happened with my Expedition. I have to use Chevron to keep the gauge working. Maybe it's a conspiracy by Chevron?
