Need help with polishing
Old Jun 11, 2007 | 03:19 PM
zx-12r's Avatar
zx-12r
Default Need help with polishing
I just picked up a used exhaust from a member and the satinless tips need a little work. What have you guys used that has worked well to polish out stainless tips and how did you do it!
They will be here in a few days so I want to get them cleaned up and on the car so I can post some pics.
Thanks,
Roy
Old Jun 11, 2007 | 03:24 PM
WetteVette's Avatar
WetteVette
Try the Car Care Discussion forum.
Old Jun 11, 2007 | 03:25 PM
C6NRED's Avatar
C6NRED
I use Mother's aluminum polish and a little elbow grease...........they will look great again.....don't be concerned when your polishing cloth turns solid black.............that is the polish taking out the impurities in the metal.
Old Jun 11, 2007 | 04:04 PM
rws.1's Avatar
rws.1
Flitz
Old Jun 11, 2007 | 04:08 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
That is what I use and I have to use it all the time as my FI setup gets the tips dirty quickly
Old Jun 11, 2007 | 04:14 PM
jovette's Avatar
jovette
suggest you use semi-chrome. It's available from motorcycle shops, works great!
Old Jun 11, 2007 | 04:44 PM
bbob67's Avatar
bbob67
That's amusing...i was just thinking about semi-chrome this morning and was wondering if it still exists. I use to buy it at Grand Auto (now extinct) stores and haven't seen it in awhile...it does work great...thanks I know where to go now.
Old Jun 11, 2007 | 05:05 PM
bobsvette55's Avatar
bobsvette55
6th Gear
Never Dull work's great
Old Jun 11, 2007 | 05:24 PM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
Heavy Metal Polish as they have a few 'more aggressive" products if the going gets tough, and NO it is not a three step product.
Old Jun 11, 2007 | 05:29 PM
bilx013's Avatar
bilx013
St. Jude Donor '12
Englishmans Showman polish is great as well...
Old Jun 11, 2007 | 05:37 PM
sunrise.cm's Avatar
sunrise.cm
Great stuff. Harley rider's favorite.
Old Jun 11, 2007 | 05:48 PM
jrprich's Avatar
jrprich
[/CODE]
Originally Posted by rws.1
Flitz
or try some polishing compound on a 4-6" buffing wheel chucked into your drill
Old Jun 11, 2007 | 06:21 PM
zx-12r's Avatar
zx-12r
Those are some great products. Do most of you use a wheel? I have one of those flitz ***** but I did not know if it would work or not.
Thanks,
Roy
Old Jun 11, 2007 | 07:17 PM
Busarider's Avatar
Busarider
Mothers, Heavy Metal, Simi Chrome etc will clean stainless up but they will not remove imperfections, stains, scratches etc like they will in aluminum. Stainless is way too hard.
Rouge and a canvas wheel is the way to go. You might have to play around a little with which rouge. I would say start with brown and hit it with green after. It will still take alot of work if the tips are in bad shape.
Old Jun 11, 2007 | 07:36 PM
Tuxblacray's Avatar
Tuxblacray
Ditto, works great... reccomended to me by the marina. (where salt water works double duty against nis shiney chrome like stuff...)
Old Jun 11, 2007 | 10:45 PM
zx-12r's Avatar
zx-12r
ttt
To Need help with polishing
