[Z06] Quater mile expectations
Went to the track my 01 z06 2 days with the high hopes of busting the 12's. Well that got shot in the nuts big time. Car had a aftermarket shifter, not sure what kind, which feels real good for just cruising but under full throttle is extremely notchy and very hard to hang the gears. The best run i could get that night was a 13.8 at 107 mph 60s were 2.3. Now i know there is atleast another half second there just on shifting and getting the launch right. After reading just about every post that Ranger has wrote i feel i can do lots better with a proper launch and practice. But is still no where near the 12's and the trap speeds seem way off. Also the track is at approx 3800 ft in elevation and most people tell me that it is about .4-.6 secs slower then sealevel. That being said i just placed an order for LT headers, Vararam and a x- pipe, and going to get in tuned, just wondering what you guys would expect someone like ranger could run in the car with these mods. Thanks
At sea level your car with the mods will crack into the 11's with good air/driver.
Good Luck and keep practicing
I'd suggest making a spread sheet of altitude corrected ETs and Traps using the "stock/super stock" entry for Roswell (Div 4) on this NHRA Chart. That way you can get your bearings by comparing the times you're running to what normally achieved elsewhere in the country.
If you do that, keep in mind two points.
(1) You don't correct for the weather (DA). No one does that.
(2) Not many tracks in the country are at sea level. Your times would be corrected literally to sea level.
Once you internalize the ET conversion at 3700', you will be more comfortable with your performance.
Finally, I can't say it often enough. It's good to get your driving dialed-in before doing the mods. The driver-mod will produce better acceleration that a car with +50 rwhp without the driver-mod.
Ranger
I'd give it more seat time before any mods. I went ahead and put the vr and dry shot because I'm no Ranger and I know thats as good as it gets for me. Good luck and hope you get your 12's soon.
It kills me when guys throw tons of money into their cars for more horsepower only to STILL be going slower then stock cars....More horsepower= HARDER TO DRIVE!!! By that I mean achieve the outcome that power CAN yield.
I wish folks would not give up so easily on their existing set ups before they go increasing them, sometimes drastically. They should be SURE they're are at the max achievements for their power level based, on reported outcomes by other members here on the forum, before opting to go the route of more money & HP= better ET's. That's usually not what ends up happening....
Practice & seat time!!!
Ron
Matt
The mods I was referring to in my above post were along the lines of a cam, heads, Turbo or supercharger or gears...
Report back on your progress!
Ron
Ron
