Misfire Cyl #1: Need help.
Old Jun 14, 2007 | 02:50 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default Misfire Cyl #1: Need help.
Application is a 97 corvette with 108500 on the clock.
I felt rough idle and the Mechanic's scanner said i have a periodic misfire on cyl #1. I suspected a bad plug or spark plug connection and took it home to check (not wanting to pay for additional labor costs for somthing i could look at) The plug and connection were both normal.
Both plugs and wires were changed in April:
- NGK Tr-55 copper plugs
- GM performance SP wires
I suspected the fuel injectors might be clogged so i ran a bottle of Lucas fuel injector cleaner through the gas tank. I still have the misfire and now it's more frequent.
Questions:
a) does this sound like an injector problem
b) should I attempt to have the injectors cleaned or purchase new ones?
c) How difficult is an injector swap?
thanks.
Old Jun 14, 2007 | 02:54 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Where the NGKs the screw on tip types? or the fixed? I had numerous problems with those plugs because the tip would loosen causing a bad relay/spark/whatever you want to call it.
Not sure if that will help, but maybe check that and it is possible that a plug where backout a little, that has happen to me too and this is caused by not ensuring they were snapped in place properly.
Old Jun 14, 2007 | 03:28 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
the plugs were regular style tips (nothing special)
spark plug was installed securly and wires were all fully connected
Old Jun 14, 2007 | 03:32 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Okay, I am curious to find out what the problem is too.
Old Jun 14, 2007 | 03:52 PM
dougbfresh's Avatar
dougbfresh
Swap coil and/or injector with another cylinder, see if it moves!
Old Jun 14, 2007 | 05:03 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Sounds like a coil to me...
Peace
Chip
__________________
..................Click for
Old Jun 14, 2007 | 05:24 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Peace
Chip
what makes you say that?
Old Jun 14, 2007 | 05:27 PM
CCA Corvette Parts
Had a couple go out on my F-Bodies in the past. One failed slowly, started out missing and then it would be fine, off and on for a while.
The second one just quit...
Easy to test, as suggested above, just more it to another spot...
Good luck,
Peace
Chip
Old Jun 14, 2007 | 06:49 PM
oaks99's Avatar
oaks99
Good luck,
Peace
Chip
Old Jun 14, 2007 | 09:20 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I don't have the scanner my mechanic has so i can't tell which cylinder is doing the missing. Does the Basic OBDII meter at auto zone haev this ability?
Also how much does a replacement coil cost these days?
Old Jun 14, 2007 | 09:24 PM
99ssconv's Avatar
99ssconv
The longer you drive it the more damage you are causing to the catalytic converter. Unburned fuel and catalytic converters don't mix. I would pay to get it fixed or plan on buying a converter also...
To Misfire Cyl #1: Need help.
