[Z06] Column Lock on '02 Z06
Old Oct 26, 2001 | 10:47 AM
Richy's Avatar
Richy
Default Column Lock on '02 Z06
Just got my new Z06 several days ago.After having a CL bypass in my ' 99 FRC ,the sound of the CL motor locking/unlocking now send shivers down my back.No bypass is presently available for the '02 models.Has anybody had a problem yet?
Old Oct 26, 2001 | 10:55 AM
jerryv's Avatar
jerryv
Default Re: Column Lock on '02 Z06 (Richy)
So far, so good. 1800 miles.
Old Oct 26, 2001 | 06:24 PM
Performin Norman's Avatar
Performin Norman
Default Re: Column Lock on '02 Z06 (Jerry Velders)
1700 miles and no problems.
Old Oct 26, 2001 | 07:56 PM
Zippy's Avatar
Zippy
Cruise-In 2, 9 & 10 Veteran
St Jude donor '09
1,400 miles of smiles! :D
Zippy :chevy :chevy
Old Oct 26, 2001 | 09:52 PM
2002EBZ06's Avatar
2002EBZ06
1485 miles and no problems.
Old Oct 26, 2001 | 11:00 PM
jrd's Avatar
jrd
500 miles and no problems...
jrd :) :) :) :) :) :) :) :)
Old Oct 26, 2001 | 11:28 PM
MUFFLER's Avatar
MUFFLER
Default Re: Column Lock on '02 Z06 (jrd)
Only 180 miles so far but no problemo. :seeya
Old Oct 27, 2001 | 04:38 AM
Azn01Penny's Avatar
Azn01Penny
1155 miles and so far so good. :cheers:
Old Oct 27, 2001 | 01:51 PM
BOBSZ06's Avatar
BOBSZ06
5800 MILES and no problems.
The 01's and 02's are no longer subject to the column lock problems of past years. :chevy
Old Oct 28, 2001 | 12:09 AM
Lefty's Avatar
Lefty
1280 Miles, of SMILES :cool: Alls Well, no issues except " Service Active Handling" displayed on DIC one time only at 200 miles.
Old Oct 28, 2001 | 12:13 AM
LymanSS's Avatar
LymanSS
Default Re: Column Lock on '02 Z06 (Lefty)
3800 miles and all is good. Haven't had an incident with it. Although it took me a while to figure out what that noise was every time the column locked.
Scott
Old Oct 28, 2001 | 08:20 AM
z06dailydriver's Avatar
z06dailydriver
1050 miles no problem
Old Oct 29, 2001 | 10:06 AM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
Does anyone know if the locking mechanism connector is the same on the 2002 as it was on previous years? If it is I will install the bypass unit I took out of the '98 Coupe we traded in on this new Z06.
:cheers: :cheers: :cheers: :cheers:
Old Oct 29, 2001 | 10:11 AM
Richy's Avatar
Richy
Default Re: Column Lock on '02 Z06 (cruiz)
Cruiz,
The earlier bypass is NOT compatible with the ' 02 factory wiring.It's also not
compatible with the recall versions of '01 and earlier.
Old Oct 29, 2001 | 01:32 PM
C5 Solutions's Avatar
C5 Solutions
I haven't heard of an '02 owner try the bypass on their car yet. My hunch is that the factory installed the recall components on the '02 cars during assembly. If so, then the bypass won't work due to differences in the wiring harness and relay.
Old Oct 29, 2001 | 10:03 PM
N4C5S's Avatar
N4C5S
Default Re: Column Lock on '02 Z06 (C5 Solutions)
WRONG. We had an incident on an 02........
It's still there folks, happened to FUBU at a hotel parking lot while I was present.....
Again, the 01's and 02's are not immune to the dreaded CL.......
JC
[Modified by N4C5S, 8:03 PM 10/29/2001]
Old Oct 30, 2001 | 08:40 AM
Richy's Avatar
Richy
Default Re: Column Lock on '02 Z06 (N4C5S)
C5 Solutions,
Tom,looks like we need you to come to our rescue
To Column Lock on '02 Z06
Old Oct 30, 2001 | 03:30 PM
C5 Solutions
Trying the bypass on an '02 with the recall (or even recalled at the factory) won't damage anything. If I can get a volunteer, I'll send you a bypass to try out.
If you DID GET the recall (or if the factory installed it) on your 6spd, you can unplug the actual lock motor from under the dash. This is the 4pin connector with purple/orange/black/green wires in it. The bypass relay in the recall will still simulate the column lock, but the actual lock will be disconnected.
Old Oct 30, 2001 | 04:19 PM
Av8ter's Avatar
Av8ter
I'm getting my EB Z06 in a couple more weeks, if you dont have a volunteer by then i would be willing to do it. And also i dont understand your second paragraph. Are you saying on the 02's 6spd that disconnecting the actual lock motor wont matter and that the relay will still simulate the lock working? if so, no codes will be thrown??
thanks
phil
Old Nov 1, 2001 | 10:27 AM
C5 Solutions
Default Re: Column Lock on '02 Z06 (Av8ter)
Thanks AV8TR, no takers yet so please email me when you get your new ride.
Your paraphrase of what I tried to say is right-on! Imagine if you will, the lock motor and bypass relay connected in a parallel circuit. With the lock disconnected, the relay still lets the BCM think everything is cool. That makes the intended setup somewhat dangerous, because the BCM could think all is well, but the steering wheel COULD actually be locked solid.
But again, we're speculating that this setup is even in the new models.
