Thanks, but not what I'm looking for. I want the one from GM.
You are correct here that is not what you want. I bought that and it is a totally different type and style of weatherstrip seal. You want the one for the side and cut it to size (you have to cut the one from Ecklers too).
Yes that is th correct part number.
The GM part affixes to the side not the bottom and it behaves more like a flap then a full seal. Check out your exisiting seal on the sides. It mounts about 1/8" below the lip.
Been there done that. I have the GM part on now. Threw away the other one.
