anyone know what rpm the rev limiter maxes out at? i thought it was at 6000. and also what does the car do if you over rev? i tryed a burnout and seemed like around 5200 or 5500 rpm the car makes a weird sound like a loud clicking is that normal?
It tops out around 6,300 and then it sounds like you've got a really bad miss as it cuts off the power.
yah clicking when im around 5200 rpm must not be a rev limiter then.also is it possible to do a burn out with traction control on? i acidently tryed forgot to turn traction off and it just pops out of 1st gear
No, you can't do a burnout with traction control on if it is working properly. There is nothing in the transmission that would pop it out of gear. You must not have had it fully in the gear. If you hold the button down for 10sec. it will put it in competitive driving mode and the ABS and Active Handeling will still work.
i found out what the clicking ratleing sound was it was the lf exhaust doughnut packing came apart it got pulled apart and was dangleing in the exhaust tube i guese i have to much horse power well 400 i think
No dont shift. Start the burn out in second gear. For a street tire I always thought first gear burnouts get the job done.
ok im new to the site and just got a frc vette and tring doing a burn out and the car would just turn off so does that mean i have to hold the trac control button for 10 secs to do a burn out
FWIW - Any tuner can reset rev limiter to any RPM desired. It's controlled by the PCM. I have a stroked & forged 382 built by Katech, and the rev limiter is set at 6,800 RPM.
When you hit the rev limiter it makes a very unique sound - Sounds like you're suddenly running on 3 cylinders.
I've got a '98. I can turn off the traction control, but holding it down for 10 seconds does nothing. Is this feature for later models only?
And I assume when you say start out in second gear you're refering to a M6....
The traction control feature senses, for lack of a better term; wheel spin. When it compares it to the front wheels and sees a big difference then it pulses the brakes to stabilize or bring the rotational speed under control, hence the name.
Holding the traction control button down for 10 seconds will put the car into Competitive Driving Mode. This turns off the traction control but the active handling feature will remain active.
