[Z06] Low Oil Pressure Issues
Old Jun 24, 2007 | 10:55 PM
LCZ06's Avatar
LCZ06
Default Low Oil Pressure Issues
01 Z06 with a 383 shortblock with an ported LS6 oil pump around 2000 miles on the motor
On a cold start the car will idle around 50-65psi. Upon total warm up the car will hang around 25-30psi.
Now what’s weird is the car can be ran hard without issue but once I get into the higher rpms 5-6k the oil pressure will stay around 16-21psi ! Also the pressure does not rise with the rpms as it stays consistent at the lower pressure. Then after around 10-15 minutes of being out of the upper rpms oil pressure will then stay slightly lower around idle levels of 20-25psi.
I checked the oil level and it’s full on the dipstick as I added a quart just to make sure. I’m running regular 10w30 valvoline for now and plan on switching over to a synthetic oil soon as maybe that will help.
I had a few ideas of what could be causing the issue as the oil pump could be bad, o ring is not working properly, oil pressure sender could be bad (giving a false reading).
Anyone experience a problem like this or have any suggestions?
Old Jun 25, 2007 | 11:29 AM
LCZ06's Avatar
LCZ06
ttt anyone?
Old Jun 25, 2007 | 12:46 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
I duno man. How do you like your 383????
Dave
PS I will check my oip preusre tonight and post back up idle warm, cruise and 5-6k
Old Jun 25, 2007 | 01:20 PM
jclarksnakes's Avatar
jclarksnakes
Your oil pressure numbers are not that terrible. One thing you might try is to add an extra quart of oil to see if that makes any difference. I am thinking that maybe after higher RPM operation it is not draining back down to the oil pickup fast enough.
Jeff
Old Jun 25, 2007 | 10:29 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
what kind of cam U running. Hyd or solid?
Old Jun 26, 2007 | 11:27 AM
LCZ06's Avatar
LCZ06
Cam is 243/250 .629/.629 112+4 cam. I'm going to try running some heavy sin oil and see if that helps 20W-50.
Dave
I like it allot besides a few little minor issues it's a great motor that pulls hard. Makes good power too. Definitely a major difference from when I had my 03 cobra. But I might go bigger one day..
Jeff
I'll try that today and see but that's a good possiblity. Appreciate everyone’s input..
Old Jun 26, 2007 | 11:33 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Screams of 0-ring to me. My buddy put a LPE blower cam in his car w/ a LS4 oil pump in prep for his Vortech install.
Fired up car... OP fine, settles into a nice 30psi or so idle (should have been more like 49 w/ the LS4 pump). Then goes for a drive... as the car gets hot the OP begins to drop and he limps home on 10psi.
Had to pull it all apart and replaced the o-ring, then all was perfect. Putting that damn o-ring in was the most gut wrenching part of my cam install.
Old Jun 26, 2007 | 11:35 AM
Boob's Avatar
Boob
I was having a similar problem. I changed the oil to fresh synthecic 10-30 and put a higher flow oil filter. I filled it 1/2 quart high and have not had any addidional issues.
BTW, what PCV system do you have? Any mods to it? I was losing oil into my intake which would run my pan low. When I'd go to full throttle I saw the pressure dip once to 20 psi around 5-6k rpm and it really worried me. I got newer PCV valve and catch can and haven't had any recent problems.
Oil PSI is around 45-50 cold at idle and around 25-35 warm. At WOT it will be anywhere from 45-60 which is where I want it.
Old Jun 26, 2007 | 11:45 AM
LCZ06's Avatar
LCZ06
I been waiting to hear back from you boob but I just saw that you posted yesterday. I'll try mine with a knn oil filter but they are expensive! I'm not running a pcv system but I just installed an catch can. Really didn't think of the pcv valve as an issue and will have to look into it. I also had to have the intake pulled apart and oil was all over the intake but I installed a catch can so that should help. My mods are as followed...
HK Enterprise 383 shortblock
TEA LS6 Stage 2.5 heads
Manton Heavy Duty Pushrods
Morel Lifters
Stock Rockers
Ported Fast 90mm intake with NW throttle body
Halltech Ti Tric CAI
Meziere Electric Water pump
Ported LS6 oil pump
Old Jun 26, 2007 | 08:47 PM
Cjunkie's Avatar
Cjunkie
new rod and main bearing with a new stock LS6 pump will fix it.
Old Jun 26, 2007 | 09:34 PM
Boob's Avatar
Boob
I wouldn't go that far yet. What I was alluding to was that you may be losing a good amount of your oil through the PCV system. As the oil level gets lower that pump will begin to suck the pan dry (not completely) to a point where it will not be able to sustain oil pressure. A cheap way to test this is to simply change the oil and make sure there will be no oil supply issues (why I went w/ a high flow oil filter& put in 7 quarts). If the pressure is where it's supposed to be directly after the change you know you were just a little low on oil. Then proceed to the PCV fix to solve the oil loss issue. Catch cans work great, but the newer model PCV valve allowed my catch can to work so much better. I haven't seen any oil loss since I've added the newer model PCV. By this time I would've need to add at least a quart. Only time will tell though.
Should this not work, I'd look to the o-ring on the oil pump. Should that not work I could see cause for concern.
Old Jun 27, 2007 | 11:48 AM
LCZ06's Avatar
LCZ06
Yeah that would do the trick but not on my wallet. But I just changed the oil and the pressure went up a little but not much. I also looked at the oil I had and it was like water not even oil and could tell that it broke down. I'm going to go with heavy 20-50 oil and try using a mechanical gauge first and see if that helps. I wanted to try the 10w30 first before using the expensive stuff. I'm going to try all the easy stuff before I tear into my motor...
Old Jun 27, 2007 | 07:36 PM
OneBadCEZo6's Avatar
OneBadCEZo6
http://melling.carshopinc.com/produc...id/78550/10296
There you go big man.. Problem solved
Old Jun 29, 2007 | 10:27 AM
5.0e303's Avatar
5.0e303
Did the oil look milky? You mentioned the oil looked watery. I m thinkin head gasket...Do you see bubbles in the coolant while running? My old stang had the same problem.
Old Jun 29, 2007 | 01:20 PM
Bad Machine's Avatar
Bad Machine
From: Rude, Loud and Aggressive! ECS Twisted Racing, "How fast do ya wanna go?"
Happened here too! All together fire it up, no effin oil pressure! Back apart sway bar rack damper ect.... Damn .05 cent effin o-ring!
To Low Oil Pressure Issues
