[Z06] 2001 z06 oil consumption issue
Dustin
What is your VIN number and the production date (located on the drives door jam)? This is for my own file as I'm finding that late production cars don't have oil consumption issues ( mine is June '01 , which is the last month of production).
GM used to require a monitoring period to verify consumption. My understanding is that the new revision rings (tighter) would be replaced (or even engines) at no charge if one quart was consumed in 1000 miles or if the owner made a big enough stink.
My '01 Z does not use oil between 5000 mile oil changes but I also don't 'hot rod' this car. I also have added a Binks coalescing filter and air/oil separator (they work the same as a oil catch tank, 'cept they work at a more efficient percentage rate).
I do support the use of an oil catch can/tank on any LS1 or LS6 that does use oil as it will reduce the buildup in the intake manifold and valves, plus prolong the life of the O2 sensors and the CATs.
Do you see indications on the rear of the car or in the exhaust tips?
Anyway , its no the end of the world.
dD
the big fix for me.when car was new ..replace the valley cover seal and breather..that took care of most of it..and since i have driven another 40k miles..its been fine...i would only re-ring if its less than 1000 mi/qt..
remember its 6.5 qts full , and then drive till ya get the message in your DIC ,low oil.and then fill the one qt...there is a lot more "fear" and mis information on this issue...than the issue itself IMO..
hope it all works out for you...drop me an email if ya got any more questions, i would be happy to ease your worry...
bud
As noted, the oil burning in the 01 was an issue. Ask the dealer to show you all logged service by GM. You want to see if the re-ring was ever done. Since you say you know who the previous/original owner is. Go talk to him. He may have traded it in because he didn't want to deal with it. Since it is out of warranty the dealer won't do the re-ring for free.
If it's burning oil at that rate and needs a re-ring. Talk to the dealer about them either doing it free of charge or tell them you want them to take the car back. That is excessive oil burning and you should be able to raise hell about it under the Lemon Law. Spending $28K on an 01 Z with 42K/mi is high in my mind.
$28 k at a dealer is a pretty good price..here in kaliforneia. they are all over the place ,from $23k-$30k depending on mi and condition, and whatever the crazy dealer or stealer decides...he can get away with..
42k is low mileage..mine is 46k and for 6yrs thats about 7k /yr
again ,good luck and i hope ya get all those questions answered..
1GYY125415101300
If you can't even get your VIN number correct ... there is little chance Chevy (GM) is gonna help you ....
The number HAS TO START with 1G1YY ...
And there HAS to be an "S" imbedded in the number someplace (assuming you have a Z06) ... so are you a troll ??? or just incredibly dislexic ?????
The GM "limit" for an "oil burner" is one quart every 1,000 miles. If the car uses more than that, GM considers it as "eligable" for a re-ring. Given that you are not the original owner (you say in your OP "I recently bought a 2001 t/red z06") I kinda doubt GM is gonna do anything to help you out.
The only thing I can recommend to you at this point is:
A) Get your facts together ... correct VIN .... original paperwork on when the car was bought .... why did the original owner not address the issue of "oil burning" ... or if they did (again paper work helps) why did the "fix" not work" ????
B) Be polite and PROFESSIONAL with the folks at the GM "Customer Service" hotline. My experience is that if you give them a "reasonable" case. they will work with you to fix the problem. Does this mean GM will pay EVERYTHING ???? Probably not at this point in time. On the other hand, maybe they will pay some part of the work to fix the problem
Ultimately, is it cheaper to just pour oil into the engine ?? It might be. See what GM will offer and decide from there what you want to do. At a few dollars a quart, unless you want to keep the car forever, it may now just be cheaper to replace oil than have the engine rebuilt.
See what GM offers on "fixing" the engine ... maybe they will still do it. Only way to find out is to call them ... but give them GOOD information ... not a VIN that is clearly wrong.
1GYY125415101300
Hopefully, he will also spell his words right.
Don't take my post personally. I have not had a chance to beat anyone else up recently.
1GYY125415101300
That's a lot! I'm sure you know some 01's have oil consumption issues, most had the re-ring done to solve the problem. Good luck..
