Armrest console door
Old Jun 27, 2007 | 07:16 PM
G8r3591's Avatar
G8r3591
4th Gear
Default Armrest console door
The center console door on my car won't open all the way. It appears that the hinge is jammed. Anybody know a trick?
Thanks, in advance.
Old Jun 27, 2007 | 07:19 PM
mkenyon's Avatar
mkenyon
Default Not really jammed
Just lift the entire lid vertically as you tilt open the lid. It is an odd hinge. It needs to lift directly up as it tilts open or it does not clear the parking brake. Seems like a hokey design to be, but it does work if you lift as you tilt.
Old Jun 27, 2007 | 07:24 PM
jrprich's Avatar
jrprich
use some small drops of oil on all the piviot points.........works wonders
Old Jun 27, 2007 | 07:26 PM
steve8's Avatar
steve8
Wd-40
Old Jun 27, 2007 | 08:30 PM
ToplessBlonde's Avatar
ToplessBlonde
WD-4- both hinges.
Old Jun 27, 2007 | 08:33 PM
Frozenfire's Avatar
Frozenfire
It feels like it won't open all the way, but it will.
Old Jun 27, 2007 | 08:46 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
NO WD-40 Use a silicone spray lubricant!!!!!!! Same effect, NO smell,,and once the spray dries the silicone is still there!
Old Jun 27, 2007 | 11:09 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
The hinge is double jointed - pull it towards you first and then up. Before we get into a discussion saying "stupid engineering" - it was done intentionally to allow a partial opening of the lid to remove something, without opening it all the way and having papers blow all over the place.
A lubricant on both parts of the hinge will make it work much easier.
Old Jun 27, 2007 | 11:12 PM
Halfway's Avatar
Halfway
St. Jude Donor '06
Make sure the e-brake is down..I know, sounds dumb.
Old Jun 27, 2007 | 11:34 PM
Old Jun 28, 2007 | 12:28 AM
jzemo's Avatar
jzemo
Old Jun 28, 2007 | 02:11 PM
dndrsn's Avatar
dndrsn
Since oiling the hinges on my Console I use the flip method to open.
Enjoy the vid:
Old Jun 28, 2007 | 02:23 PM
ClovisFox's Avatar
ClovisFox
I would guess that the engineers designed it this way so that the lid would clear the e-brake handle when open. Not sure that was the best approach. Should have used a rear hinge that would open 180 degrees...IMHO.
Gene...
Old Jul 3, 2007 | 07:34 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
I was having issues with my door too. When I got to looking at it, one of the little arms on either side was missing the connecting rivet and they were just laying there loose. The main part of the hinge still works, but without these other pieces connected, the lid doesn't pivot outward to avoid rubbing on anything when opened.
Any thoughts on where to get some small rivet type connectors?
To Armrest console door
