[Z06] Z06 RPO Code
Old Jun 28, 2007 | 03:51 PM
02MillenniumVette's Avatar
02MillenniumVette
Default Z06 RPO Code
Need some help from the Z06 guys here. Does anyone know what the RPO for the C5 Z06 is? Like the RPO for the C6 Z06 is 1LZ and 2LZ. Thanks in advance.
Old Jun 28, 2007 | 04:06 PM
mark896's Avatar
mark896
Hmm... Not sure if there is one.. I always just look for "LS6" on the sheet.
Old Jun 28, 2007 | 04:16 PM
02MillenniumVette
Yea I know about that. I just didnt know what the RPO's were, if there even is one, for the C5 Z06. Like when you ordered a C5 Z06, was there a RPO for it like the C6 Z06, 1LZ for one package of the Z06 and 2LZ for another package of the Z06. I know the base C5 was either a 1SA or 1SB. Hope I havent confused anyone yet.
Old Jun 28, 2007 | 04:18 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Someone correct me if im wrong....
On the C6Z the 1LZ and 2LZ are "Option Packages". One option package will be more expensive because it has more options. I think the 2LZ option is the highest $$ option.
There were only 4-5 options on the C5 Z06 so I don't think they had option packages for it.
Toque
Old Jun 28, 2007 | 04:24 PM
02MillenniumVette
Toque
I know the 1LZ and 2LZ on the C6Z are option packages. I think Ive already figured out my answer, which is basically what you said, I dont think there were any options for the C5 Z06 as in packages, just seat colors, wheel options, etc.
Old Jun 28, 2007 | 04:44 PM
bluestreak63's Avatar
bluestreak63
Correct, no option packages, just a few RPO codes for options like Body Side Moldings, Electronic Monochromatic Mirrors, Front License Plate Frame, may have been another one depending on year. No wheel options for Z06. In 01, you got the forged Alcoa wheels, and in 02-04, you got the cast spun Speedlines, both in that gunmetal color.
Old Jun 28, 2007 | 04:45 PM
UstaB-GS549's Avatar
UstaB-GS549
The only RPO was for the 2004 special edition Z06 which was a Z16. Otherwise the hardtop (Z06) code is one of the digits in the VIN.
Old Jun 28, 2007 | 09:33 PM
lawZ's Avatar
lawZ
ZO6 was the RPO code.
Old Jun 29, 2007 | 05:44 AM
mark896's Avatar
mark896
No.
Old Jun 29, 2007 | 10:39 AM
02MillenniumVette
Z06 is the model not the RPO.
Old Jun 29, 2007 | 11:15 AM
BlackZ06's Avatar
BlackZ06
Not to nit-pick .... but depends on which year Corvette you're referring to.
In 1963 you could order a Corvette with RPO Z06, which was a "race" package that included upgraded suspension, brakes, a larger fuel tank, and the 327 cu. in. engine with fuel injection rated at 360 HP.
That option code became so "famous" that when Chevy came out with the C5 with a "race" package, they named it after the old RPO code ... hence our MODEL is called the Z06.
Old Jun 29, 2007 | 09:06 PM
ErnieN85's Avatar
ErnieN85
I was just looking at my build sheet and window sticker
The window sticker says 2002 CORVETTE z06
The only options were
memory package
electrochromatic mirrrors & body side moldings
now for the different part
the build sheet says Z06 then lists the various RPO's includes stating Z06 after each
ar9 base seat
B84 mldg
CJ2 a/c elect
DD8 ls mirror
FE4 Z06 susp
GU6 3.42 axel
LS6 5.7l Engine Z06
m12 6spd trns Z06
uno am/fm cd
uz6 Bose spkr
u73 fixed ant
xfw tire
yfu tire
p12 Z06 whls
so it seems that as with many of Gm's stuff it's a bit ambigous as wether or not Z06 is a model or RPO code or both
Old Jun 29, 2007 | 09:42 PM
Dangerous's Avatar
Dangerous
Info for a 2001 Z06...
RPO Description Cost Production Percent
1YY37 Base Hardtop - Z06 Model $48,055 5,773 16%
1AY Stock Order Processing Code $0 NA NA
1SA Corvette Hardtop Base Equipment Group $0 5,745 99.5%
AAB Memory Package (Requires DD0) $150 4,780 83%
AG1 Power 6-Way Driver Seat (Std. on Z06) $0 5,773 100%
AK5 Inflatable Restraint System $0 5,773 100%
AR9 Driver & Pass. European Bucket Seats NA 5,773 100%
B34 Floor Mats $25 5,690 99%
BGR Bowling Green Plant Processing $0 5,773 100%
B84 Body Side Moldings $75 2,955 51%
CJ2 Dual Zone Climate Control $365 5,773 100%
CV3 Mexico Export Option NA NA NA
DD0 Mirror, Inside, Light Sensitive $0 5,773 100%
DL5 Decal, Roadside Service Information $0 5,773 100%
EXP Export Option NA NA NA
FE4 Performance Handling Package - Z06 NA 5,773 100%
FE9 Federal Emissions Certificate NA 4,309 75%
GU6 Performance Axle Ratio (3.42) NA 5,773 100%
IP4 Trim, Interior Design (RPO Z06) NA 5,773 100%
JL4 Active Brake Control NA 5,773 100%
JL9 Brake System,Front/Rear Antilock NA 5,773 100%
K63 Generator, 110 Amp $0 5,773 100%
LS6 Engine, 5.7L Alum, 385 HP $0 5,773 100%
M12 6-Speed Manual Transmission (Unique to Z06) NA 5,773 100%
NB8 CA/Northeast Emission Certified $0 NA NA
NF7 Emission System, Federal, Label $0 5,773 100%
NG1 Massachusetts/New York Emissions Requirements $0 NA NA
NK4 Steering Wheel, Sport Leather $0 5,773 100%
QE1 Wheel (RPO Z06) $0 5,773 100%
R6M New Jersey Surcharge (mandatory in NJ) $0 NA NA
R8C NCM Delivery Package $490 NA NA
U52 Instrument Cluster, Electronic NA 5,773 100%
U73 Antenna, Fixed, Radio (FRC) NA 5,773 100%
UL0 AM/FM Stereo/Cassette -$100 70 1%
UN0 Stereo System Delco-Bose with CD NA 5,703 99%
UZ6 Speaker System, 6, Quad, Dual Quarter NA 5,773 100%
V49 Front License Plate Frame $15 3,285 57%
V73 Vehicle Statement, US/Canada $0 5,773 100%
VM3 Label Information, Consumer $0 5,773 100%
XFW Tire, Front, P265/40ZR18 $0 5,773 100%
YFU Tire, Rear, P295/35ZR18 $0 5,773 100%
Z49 Canadian Options $0 284 4.9%
Color Options
RPO Color MFR Code Cost Total Percent
12U Quicksilver Metallic WA-519F $0 1,345 23%
40U ** Speedway White WA-8554 $0 352 6%
41U Black WA-8555 $0 1,719 32%
70U Torch Red WA-9075 $0 1,623 22%
79U Millenium Yellow WA-423G $600 634 11%
** Of the 352 Speedway White Z06s, 215 were built with black interior and 137 were built with the black/red interior.
Interior Color Options
RPO Color Production Percent
19I Black 4,112 71%
70I Black w/ Torch Red seat inserts, lower dash and lower doors (opt). 1,661 29%
Canadian Production
12U Quicksilver Metallic 65 23%
40U Speedway White 12 4%
41U Black 73 26%
70U Torch Red 54 19%
79U Millenium Yellow 80 28%
RPO Model Total
1YY37 Base Hardtop - Z06 Model 284
Note: Manufacturer paint code number for the 2001 Z06 wheels is WAPB-9789
MadMaxZ06's Avatar
MadMaxZ06
Just for informational purposes:
Non-Z06 VIN = 8th digit in the VIN is a "G"
Z06 = 8th digit in the VIN is a "S"
One site that knows this is AllData: http://www.alldata.com/TSB/011006_en.html
- Max
Old Jun 29, 2007 | 09:51 PM
Dangerous's Avatar
Dangerous
- Max
More info on 2001 Z06 - Serial Numbers -
1G1YY12S515100000 - 1G1YY12S515105773
Digit Definition
1st Country of Origin: 1 = USA
2nd Manufacturer: G = General Motors
3rd Make: 1 = Chevrolet
4th/5th Carline/Series: YY = Corvette
6th Body Style: 1 = hardtop
7th Restraint Code: 2 = Active, manual w/ driver and passenger inflatable restraints.
8th Engine Type: S = LS6
9th Check Digit
10th Model Year: 1 = 2001
11th Plant: 5 = Bowling Green, Kentucky
Last 6 digits Production Number starting with 100000 - 105773.
Old Jun 29, 2007 | 10:00 PM
BlackZ06's Avatar
BlackZ06
- Max
MadMaxZ06,
The 8th digit of the VIN code is used to show "Engine" ... the VIN layout is as follows and is true for ALL cars sold in the US .. I've included in parenthesis the C5 Corvette applicable codes ...
Position ............... Definition
1.........................Country of Origin (1 = US)
2.........................Manufacturer (G = GM)
3.........................Division (1=Chevrolet)
4-5......................Carline/Series (YY = Corvette)
6.........................Body Type (1=Z06, 2=Coupe,3=Convertible)
7.........................Restraint System (2=Manual Belts with Drvr/Psgr Airbags)
8.........................Engine (G=LS1, S=LS6)
9.........................Check Digit (calculated based on other digits in VIN)
10........................Model Year (1=2001)
11........................Assembly Plant (5=Bowling Green)
12-17....................Plant Sequence Number
Old Jun 29, 2007 | 10:14 PM
BlackZ06's Avatar
BlackZ06
Dangerous ... you beat me to it .....
To Z06 RPO Code
Old Jun 29, 2007 | 10:46 PM
MadMaxZ06's Avatar
MadMaxZ06
MadMaxZ06,
10.........................Model Year (1=2001)
11.........................Assembly Plant (5=Bowling Green)
Thanks.
- Max
Old Jun 29, 2007 | 10:58 PM
Dangerous's Avatar
Dangerous
smoked you by 9 minutes.... You just took the time to make yours pretty...
Old Jun 30, 2007 | 06:03 PM
02MillenniumVette
Thanks for all the help guys.
I know the '63 Z06 had a RPO Z06 but I originally asked about the C5 Z06 and Im in the C5 Z06 section.
