I didn't know I had clutch problems until...
Old Jun 28, 2007 | 10:05 PM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
Default I didn't know I had clutch problems until...
Until I decided to follow Ranger's clutch fluid replacement protocol.
http://www.rangeracceleration.com/Clutch_Care.html
My 2001 C5 shifted fine. The clutch did not stick to the floor and I read his article before and being a newbie had no idea what the term pedal 'woes' meant until I did this change. I was like "I don't have them"
I am totally stock...I do not race on tracks like Ranger and did this more out of a preventative maintenance.
I was shocked how 12oz of pure black fluid came out in about 6 fill and drain w/ 20 hard pumps per fill.
Once it was clear I took it out for a drive.
wow!!! The clutch felt so "right" and on some high speed acceleration the shifting smoothness was amazing.
I TOTALLY RECOMMEND YOU DO THIS PREVENTATIVE MAINTENANCE Even if you are stock. It took me 30minutes and was well worth it.
Old Jun 28, 2007 | 10:11 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
I will remember this thread when I finish the garage collage if it is still raining. Good sounding info! What do you think FRC?
Old Jun 28, 2007 | 10:19 PM
stormrider's Avatar
stormrider
Good stuff. Thanks
Old Jun 28, 2007 | 10:44 PM
OleStraightStick's Avatar
OleStraightStick
St. Jude Donor '08
awesome info... i'll definitely check mine out.. thanks for sharing
Old Jun 28, 2007 | 10:52 PM
Blown 346's Avatar
Blown 346
Mines black Looks like I'll be spending some time in the garage.
Old Jun 28, 2007 | 11:05 PM
rws.1's Avatar
rws.1
103K miles... original clutch
clear fluid in clutch M/C and no clutch woes...
I have been using this approach for 3 years.....
Old Jun 28, 2007 | 11:13 PM
DGW's Avatar
DGW
On your next oil change, change the trany fluid with royal purple synchromax, you will be amazed, bigger difference than the clutch fluid. PM me and I can forward you the pm's I got on how to from BobbyG...
Old Jun 28, 2007 | 11:14 PM
Daytona Bob
For the record *I* purchased Dot 3 fluid penzoil synthetic.
The difference between that and Dot 4 is the temperature rating.
Since I dont track the car I'm ok with stock Dot 3 like I mentioned.
I'd think you would want Dot 4 if your tracking it.
Be sure to read bottle for compatibility with Dot 3 and brake/clutch systems
Rangers thread goes into excellent detail.
I'll post pics tommorow of the old fluid and my unique "syringe"
LOL
Old Jun 29, 2007 | 01:01 PM
Ranger's Avatar
Ranger
Glad it worked out for you, Angrybob.
My approach to clutch fluid preventative maintenance was borne out of necessity on my 01 Z06.
Suffered pedal woes; Chevy fix of swapping all the clutch and hydraulic parts worked for only a short time before pedal woes returned. Experimentation led to persistence in keeping the clutch fluid clean and fresh (that means clear of any murkiness), putting the boiling point near the number on the can. For me, problem solved. Is working for hundreds of other owners too.
Ranger
Old Jun 29, 2007 | 01:11 PM
z06 hellcat's Avatar
z06 hellcat
Old Jun 30, 2007 | 05:29 PM
Daytona Bob
Here is a picture of the dirty fluid and my patented removal tool.
As you can see the fluid is just aweful. The Bottle was clean when i started.
If your looking for a portable unit then Ranger's portable zip lock system is the way to go.
I was looking for the perfect home syringe and came across my wife's turkey flavor injector!!
Isn't she a beauty??
I'm safe until Turkey day anyway from any wrath!!
Remember to use plenty of shop towels and...
Next up is the Royal Purple MN6 Change and Differential Fluid change.
Old Jun 30, 2007 | 05:33 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Ranger is the man! I follow his intructions as well. I do it every month
Old Jun 30, 2007 | 05:42 PM
Bob CTS's Avatar
Bob CTS
Another satisfied Ranger technique user, I am up to ~19 changes and what a difference, I also just got back in from draining the manual transmisison and refilling with Mobil 1 SYN ATF and wow the shifter fill so much better.
Angrybob do not be surprised if within a day or two driving the fluid gets a little murky again mine was as dark as the fluid you got out also.
Great job for posting your findings Ranger.
Old Jun 30, 2007 | 09:44 PM
the Vetteman3's Avatar
the Vetteman3
So easy, a caveman could do it. There is no reason to have dirty cluch fluid. This is probably one of the most important things I've learned about taking care of my vette.
Thanks Ranger!
Old Jun 30, 2007 | 10:44 PM
C5naples's Avatar
C5naples
Nice tip, thanks!
Old Jul 1, 2007 | 12:30 AM
rustyguns's Avatar
rustyguns
i did it and it is fricken' wonderful !!
Old Sep 9, 2007 | 05:19 PM
Jet-Jock's Avatar
Jet-Jock
Default 6-Speed Clutch Fluid Reminder
This one been asleep for a while but it's a good reminder for 6-speed owners.
I'm doing mine about every four months and it stays fairly clean during that period of normal type driving.
I use GM Clutch Fluid 12345347. Oh and I also have one of those Mighty Vacs which makes removing the fluid real easy and safe.
Just a reminder is it time for you to change yours?
To I didn't know I had clutch problems until...
Old Sep 9, 2007 | 11:10 PM
INaband's Avatar
INaband
CI 7-8 Veteran
Worked for me, also..
Old Sep 10, 2007 | 08:32 AM
Plasticfan's Avatar
Plasticfan
I've used both these tips(RP and clean clutch fluid) on my 02 6 spd in the past month. Both worked great. Easy to do and cheap as well. One more reason I love this forum.
Old Sep 10, 2007 | 10:49 AM
painkiller's Avatar
painkiller
Default Clutch Fluid
