Really, Hype or help....
Old Jun 29, 2007 | 06:36 AM
sdspeed's Avatar
sdspeed
Default Really, Hype or help....
Ok, an after market air cleaner and coupler, and a cat back exhaust system and maybe even a MAF. You can take out $1500 to $2k easily. Besides sounding better what have I got for my money?
Can you really do much to improve on the C5 Performance on a CA. Smog Budget??
Old Jun 29, 2007 | 06:53 AM
Covert 405's Avatar
Covert 405
You've busted out some extra ponies (but not many). If you wanted to go further you've got a good baseline for the more high-dollar mods like heads/cam, LT's, high flow cats, intake and a tune. Residing in PA, I'm not sure how to go about that in CA but there are plenty of people on here that do.
G'luck.
Old Jun 29, 2007 | 07:38 AM
sdspeed's Avatar
sdspeed
Default where to spend $$$
I guess I'm wondering if the money wouldn't be better spent on maybe suspension or even a 3.90 rear end for my 2001 C5 6 speed. I get
performance,instant gratification and it's do able for less tha $2k and still maintain daily reliablity. I really don't like the shifter, will a C6 ZO6 bolt in without mod's. Brand new kit for less than $200!
Old Jun 29, 2007 | 08:23 AM
You're right - those mods won't get you much in terms of HP. Gears won't either, but they will make the car respond better. California does make it difficult for performance bumps.
Old Jun 29, 2007 | 08:42 AM
roscoe118's Avatar
roscoe118
Yep, so easy even a cave....,I, could do it
I've done the intake and exhaust, and this was the best $80 (bought it in the Parts for Sale section) that I've spent on this car so far
Old Jun 29, 2007 | 11:26 AM
sdspeed's Avatar
sdspeed
Did you install a C6 ZO6 or a C5 ZO6 Shifter. I'm told the C6 Z06 shifter works really nice!
Old Jun 29, 2007 | 11:37 AM
DefenderC5's Avatar
DefenderC5
Long tube headers are really your only major restriction. You can do heads/cam setups, but some of the more aggressive cams will fail smog. Nearly all the FI kits (supercharger, twin turbo) are CARB approved though. The APS twin turbo uses its own manifolds so there is no need for LTs... it will pass smog. But these aren't really "budget".
But as far as minor upgrades... perhaps a gear swap would give you the most bang for your buck.
Old Jun 29, 2007 | 11:42 AM
sdspeed's Avatar
sdspeed
That opens up a new area of concern, if I go with a supercharger and really BLOW my budget then don't I really need the exhaust and intake sides to take advantage of what the Supercharger is gonna produce.
Sorry gang i build airplanes now not cars, they were years ago when smog wasn't an issue!!!
Old Jun 29, 2007 | 12:52 PM
Covert 405's Avatar
Covert 405
Yes. If she breathes she needs to be able to fart.
Old Jun 29, 2007 | 04:00 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
If you do a supercharger you won't be able to use a CAI. With the mods you have (especially living in Cali) I would suggest the biggest bang for the buck is a ratio change. 4.10 for a MN6/M12 car or 3.42 for an A4. East Coast installed my 4.10s and I'm very happy with the improvement in driveability and yes fuel economy.
Old Jun 29, 2007 | 09:02 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Seriously, listen...
Do the 3.90's before you do anything else...
Peace
Chip
__________________
..................Click for
To Really, Hype or help....
