Back up light lens
Old Jul 1, 2007 | 12:16 AM
Slipjoint's Avatar
Slipjoint
Default Back up light lens
i'm sure this mod has been posted a bunch before but i just blacked out my back up lights lens - it looks so much better to me over the OEM look & they still function as a back up light! cost of Mod. - almost free - T
Old Jul 1, 2007 | 12:42 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
What did you use?
Old Jul 1, 2007 | 01:09 PM
Slipjoint's Avatar
Slipjoint
Originally Posted by clayton1
What did you use?
Remove the license plate bracket – the clear lens are glued to the black housing – all I did was sprayed the inside of the lens thru the hole that the bulb fit in – spray in plenty of black paint – then move bracket around and watch the paint flow inside the lens – you will be able to see the paint – shoot in another dose of rattle can if you need to let it flow around – you will be able to tell when everything is covered – let dry – then do the same to the other side - - very very simple – as you can see in the pix it looks very dark but when you turn on the back up light they still function pretty good – I’m very pleased - T
Old Jul 1, 2007 | 01:11 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Looks great and I love blacked out Vettes
To Back up light lens
