Got wierd problem... Need help
Old Jul 1, 2007 | 09:58 PM
jgmachine's Avatar
jgmachine
Default Got wierd problem... Need help
Ok, here is the deal. I got a 03 Z. The other day I left a friends house and punched the gas hard when I left. So my check engine light went on and on the DIC, it said Active Handleing Warming up. It cleared up a few seconds later but the check engine light was still on. I came home and cleared the code(it was a history code) and the check engine light went off.
Today I pulled the car out of my garage and again the DIC said Active Handleing Warming up. It drove for over 20 minutes and finally it turned off. Later, I started it up and it happend again. This time it turned off in about 15 minutes.
What the heck is going on??? THANKS IN ADVANCE.
Old Jul 1, 2007 | 10:11 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Its normal for that message to come up every once in a while but not that often. I suspect EBCM is going hay wire.
Old Jul 1, 2007 | 10:15 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
The "active handeling warming up" message is pretty normal. Post the code you pulled from the DIC for the check engine light.
Old Jul 2, 2007 | 02:22 AM
LLVETTE's Avatar
LLVETTE
Hmm, my active handling message comes up at the end of some autocross runs??
Old Jul 2, 2007 | 04:50 AM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
post all the listed codes. should only come on for a little while. I had the same problem. mine was the IAT sensor harness was bad
Old Jul 2, 2007 | 08:12 AM
rws.1's Avatar
rws.1
I get the active handling warming up during auto-x events as well.
As i understand it , the car needs to move forward in a straight line a defined number of feet for the system to warm up. During that time if you get into a condition where the system thinks it should apply itself, it does, but gives the warming up message.
Normally it takes just as long to warm up, put everyday driving usually does not put you into a loss of traction at one of the four corners that initiates the Active handling system intervention.
Old Jul 2, 2007 | 08:14 AM
BUBBAS 01Z06's Avatar
BUBBAS 01Z06
I had that happen two times.....It just went away...
Old Jul 5, 2007 | 08:07 AM
jgmachine's Avatar
jgmachine
OK - problem continues. It happend this morning on my way to work. my ride is only 8 miles and the "active handeling warming up" never even turned off.
THe code is a 10-PCM P0113C
Can anyone help?
Old Jul 5, 2007 | 08:35 AM
DAVS Y2K's Avatar
DAVS Y2K
Banned Scam/Spammer
https://www.corvetteforum.com/techti...D=26&TopicID=1
Looks like air intake sensor.
Old Jul 5, 2007 | 01:43 PM
jgmachine's Avatar
jgmachine
How the heck could this affect my active handling?
Old Jul 5, 2007 | 02:34 PM
GOZ2FST's Avatar
GOZ2FST
Your car has gone bad. You need a new one.
Old Jul 5, 2007 | 11:34 PM
Whiteonrice's Avatar
Whiteonrice
To Got wierd problem... Need help
