[Z06] High idle
Old Jul 2, 2007 | 03:12 PM
zbzo6's Avatar
zbzo6
Default High idle
I have 02 ZO6 all stock except for a blackwing air filter. This past sunday after I took it out for a drive I noticed it idleing a little high.It would not come down below about 800 rpm. Any suggestions ? Thanks Zach
Old Jul 2, 2007 | 04:55 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
this may help
http://forums.corvetteforum.com/show...ghlight=sleazy
Old Jul 3, 2007 | 04:49 AM
GHOSTRIDERZ06's Avatar
GHOSTRIDERZ06
Default High Idle Z06
I am sure that you have already read above having a clean MAF sensor about also make sure the motor is no pulling un-metered air from a loose hose, IE, Throttle body air bridge or MAF connection. This can also cause the high idle condition you are describing. My 01 Z06 also did this after I inadvertenly over tightened my air bride to throttle body hose after installing a SLP air bellow. It happened right after I started the car.
Old Jul 3, 2007 | 05:48 PM
MarkT 2002's Avatar
MarkT 2002
At stock, I thought they are set to idle at 800rpm?
Old Jul 4, 2007 | 07:54 PM
bluestreak63's Avatar
bluestreak63
That's where mine sits at idle and it's bone stock down to the AC Delco air filter.
Old Jul 5, 2007 | 06:56 AM
SMR 67's Avatar
SMR 67
Doesn't sound like you have a problem.
To High idle
