side body molding?
Jul 3, 2007 | 12:56 PM
side body molding?
Anyone know what is the process/ how difficult it is to remove the side body molding on my C5? I think the car would look more sleek without it.
Jul 3, 2007 | 01:02 PM
hair dryer, fishing line, goo gone
Jul 3, 2007 | 01:08 PM
is it work the effort? as far as the end result? and i hope no holes to fill.
Jul 3, 2007 | 01:09 PM
Quote:
Originally Posted by
Limp Noodle
and the search button
Jul 3, 2007 | 01:35 PM
Cruise-In IX Veteran
Hope this helps
Jul 3, 2007 | 01:45 PM
One comment, do a thorough inspection to make sure no work has been done to the door (i.e. bottom section painted). I just used some spider wire fishing line and took mine off. Drivers side flawless, passengers side line down the side on the lower part of where the molding was. After further inspection there was some work done to the lower part of the passengers door. After several hours of work, including wet sanding, the line is almost none existent however you can still barley see it if you are really looking for it.
But yes, heat either with hairdryer or shrink tube gun and fishing line will take them off. Then I used some goo gone to remove most of the tape and claybar to clean it up. Make sure you put a good coat of polish on the area when finished.
Good Luck
Jul 3, 2007 | 01:53 PM
I took my C5 to a local body shop, they did it in about 20 minutes for a 6 pack of beer and $10.
No holes to fill and the car looks much sleeker / cleaner IMHO.
Jul 3, 2007 | 01:57 PM
Here are some before and after shots:
BEFORE:
AFTER:
Jul 3, 2007 | 01:58 PM
Vampyre
your gonna like the way it looks.
Jul 3, 2007 | 02:28 PM
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi ZeroHer0 -
http://forums.corvetteforum.com/show...ght=remove+bsm
I used "remove BSM" in the search - many hits there -
Easy job - take your time and all is fine.
best regards-
mqqn
Jul 3, 2007 | 02:55 PM
thanks a lot everyone!
The before and after pics are awesome...they help to make the decision.
Jul 3, 2007 | 03:00 PM
This is what BSMs look like to me. And they also come in different colors.
Jul 3, 2007 | 05:37 PM
DEFINATELY take them off... car looks much nicer.
Jul 3, 2007 | 10:54 PM
BEFORE....
AFTER......
