[Z06] Air Tubes on Headers / Air Pump
Old Jul 3, 2007 | 01:53 PM
distinctz06's Avatar
distinctz06
Default Air Tubes on Headers / Air Pump
I disconnected my airtubes and blocked off the flanges on the headers, im following the tube which goes down to the intake, i think it goes through the air pump first am I correct? If so does that mean I can turn off the air pump with HP tunners and also disconnect the line that goes to the airbox and plug it?
Old Jul 3, 2007 | 03:23 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Yes, if you are removing the pump you can remove ALL lines too. Just edit out the code and you are good to go.
Old Jul 3, 2007 | 03:41 PM
distinctz06
the air pump is useless when you dont have it connected to the headers correct?
Old Jul 3, 2007 | 05:38 PM
Tech's Avatar
Tech
Yes.
Old Jul 4, 2007 | 04:15 AM
ICaughtVetteFever
Worse than useless, it becomes dead weight. Strip it all and sell it in the parts section for more mod money.
Old Jul 5, 2007 | 04:43 PM
seebobgo's Avatar
seebobgo
I removed my pump when I put on the supercharger and made room for the blow off valve. Edit out the code and good to go. To redeem myself, I went out and hugged a tree.
To Air Tubes on Headers / Air Pump
