Leaky Tire Pressure Sensor...
Old Jul 4, 2007 | 01:22 PM
spdnman's Avatar
spdnman
Default Leaky Tire Pressure Sensor...
The sensor is leaking air. Not by the cap, but where the shaft meets the base of the metal on the rim itself. Do I need a new sensor or can it be fixed? Thanks.
Old Jul 4, 2007 | 03:10 PM
Bakersfield's Avatar
Bakersfield
You just need an o-ring. I think it is a #14 o-ring that you can get from any hardware store for about 15 cents.
Old Jul 4, 2007 | 05:12 PM
jarsdad1's Avatar
jarsdad1
Not wanting to hijack, but...the early sensors have an o-ring IN the sensor. Does another ring go between the sensor and the wheel?
Old Jul 4, 2007 | 06:23 PM
spdnman's Avatar
spdnman
I'd like to know as well. I think I need to order a sensor.
Old Jul 4, 2007 | 07:07 PM
spdnman's Avatar
spdnman
I just checked again and the leak is where the nut meets the stem. This is on a 1998. Do I need an O-ring or a new sensor?
Thanks.
Old Jul 4, 2007 | 07:15 PM
Spolioli's Avatar
Spolioli
I have fill my 04 tires every 2 weeks or so. One time I even heard air hissing out of the right rear valve stem seat. I tightened it up and it was ok, but i still have to check all four tires every two weeks or so. My 05 never looses air. I can check it months after filling and all four still have 30psi.
Old Jul 4, 2007 | 08:00 PM
Brad@RevXtremeAutoSports's Avatar
Thanks.
New "O" ring. Just replaced mine on my '98.
brad
Old Jul 4, 2007 | 08:08 PM
spdnman's Avatar
spdnman
brad
Cool. Do I have to dismount everything? If not, does the O-ring go on the stem or the back of the nut? Thanks again....
Old Jul 4, 2007 | 08:33 PM
Bakersfield
My 98 has the o-rings on the valve stem too. Just have your tire store break one bead of the tire off of the rim, remove the sensor, and put a new o-ring on the valve stem and re-assemble. If they don't take the tire completely off, then there should be no need to re-balance the wheel.
Old Jul 4, 2007 | 08:36 PM
spdnman's Avatar
spdnman
Thank you. Should save me $100.
Old Jul 4, 2007 | 08:52 PM
spdnman's Avatar
spdnman
Can you tell me the size of the O-ring needed?
Old Jul 4, 2007 | 10:09 PM
Probably just a bad O-ring. Get a new one and have it installed.
Old Jul 5, 2007 | 10:50 AM
Bakersfield
Like I said in my earlier post, I believe it is a #14 o-ring......
Old Jul 5, 2007 | 10:55 AM
04cad's Avatar
04cad
St. Jude Donor '07-'08
I assume you have checked to make sure the nut doesn't need snugged up? Some times seals take a "set" and lose the compression a bit and snugging up the retainer stops the leak. Good luck
Old Jul 5, 2007 | 12:19 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I thought the older style was a #9 for some reason....
Old Jul 5, 2007 | 01:02 PM
Bakersfield
Yea, I think you are right, #9 sounds right. I tried to find that here on the forum but I was not able to find it. But thanks for jumping in.
Old Jul 5, 2007 | 03:37 PM
spdnman's Avatar
spdnman
Thanks. I did try that and made it worse. Does anyone know where to get a #9 O-ring? I cannot find any.
Old Jul 5, 2007 | 03:39 PM
Bakersfield
Any hardware store will carry rubber O-rings.
To Leaky Tire Pressure Sensor...
