Hood Emblem remove on the hood
Old Jul 6, 2007 | 07:28 AM
corvettejaune's Avatar
corvettejaune
Default Hood Emblem remove on the hood
I will like to no if the paint on my hood gone to be damage if i remove the Hood Emblem to put a new one and how i c'ant remove hit
thanks and advance and regard
Corvette jaune
Old Jul 6, 2007 | 07:30 AM
65GGvert's Avatar
65GGvert
Fill out your profile. I'm assuming you are in a country other than US and we don't even know what car you have.
Old Jul 6, 2007 | 07:31 AM
jdmvette's Avatar
jdmvette
Night Owl for life
no just saw it off with fishing line and then clean up the residue.
Old Jul 6, 2007 | 07:34 AM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
The hood emblem has a guide hole that will need to be filled unlike the trunk emblem.
Old Jul 6, 2007 | 07:38 AM
jdmvette's Avatar
jdmvette
Night Owl for life
the OP says he's going to replace it with another one.
Old Jul 6, 2007 | 07:45 AM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
Oops, I was reading it in english...........
Old Jul 6, 2007 | 07:47 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Some of the folks here have removed theirs and there are holes to contend with unlike the rear deck emblem. How is the front emblem secured to the fascia?
Old Jul 6, 2007 | 09:27 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Old Jul 6, 2007 | 10:12 AM
dougbfresh's Avatar
dougbfresh
I think there are speed nuts on the 2 posts that go thru the fascia.
Old Jul 6, 2007 | 10:29 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
the front hood emblem is held on by 2 sided tape, but there are also plastic pins that fit into 2 holes in the hood, so the emblem is aligned properly when it is installed. To remove it I would suggest that you heat the emblem with a hair dryer - this will soften the adhesive so it can be gently removed by lifting it upwards. The alignment pins are not secured - they just fit into the holes. The rear emblem does not have the alignment pins. I hope this helps you.
Old Jul 6, 2007 | 11:51 AM
z06Bigbird's Avatar
z06Bigbird
Room here for only one smart aleck. That be........??
Old Jul 6, 2007 | 11:52 AM
z06Bigbird's Avatar
z06Bigbird
Lots of speed nuts on this forum--you are in wrong section.
Old Jul 6, 2007 | 02:05 PM
The hood emblem is held on with two sided tape and it also has two pins that go into holes in the front fascia. Use a hair drier to heat up the emblem and soften the tape. You should be able to use some fishing line and saw through the tape then or you may be able to just pull up on the emblem and take it off.
Old Jul 6, 2007 | 02:44 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
mine didn't have any speed nuts, just the two plastic pieces that go in the mounting holes.
To Hood Emblem remove on the hood
