chassis dyno do's, don'ts
Old Jul 6, 2007 | 05:57 PM
katana ace's Avatar
katana ace
Default chassis dyno do's, don'ts
gonna let the instructors and students in our summer high performance class chassis dyno my '00 coupe next week. do I instruct them to set in competitive mode or not? anything else I need to be thinking of beforehand?
Old Jul 6, 2007 | 06:04 PM
Singer Island C5's Avatar
Singer Island C5
Default Great question.
I'm sending my blown vert for dyno testing next week and outside of clean air filter, fresh oil and blower juice I don't know if there's really anything else to do. Do any of the CF tuners have any input on this?
Old Jul 6, 2007 | 06:18 PM
jzemo's Avatar
jzemo
i have an appointment on the 12th for my dyno...not sure when yours is but i'll let you know which mode we have mine in
Old Jul 6, 2007 | 07:12 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Does it make a difference? I don't understand how it would.
Old Jul 6, 2007 | 07:14 PM
TM-Z06's Avatar
TM-Z06
On the dyno - turn traction control completely off.
Old Jul 6, 2007 | 07:17 PM
Mick_C5's Avatar
Mick_C5
Old Jul 6, 2007 | 07:38 PM
reactor2's Avatar
reactor2
Turn off the traction control. Dyno numbers should be taken from 3rd gear (automatic) and 5th gear (manual).
Old Jul 6, 2007 | 08:46 PM
XKR100's Avatar
XKR100
St. Jude Donor '08-'09
Old Jul 6, 2007 | 08:54 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
My 2000 MN6 goes on the dyno in the morning! First time! I'll be watching this thread all night! Thanks in advance for the pointers!
Old Jul 6, 2007 | 09:22 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I was going to PM you to remind about the pics of the dyno day and the dyno chart
Old Jul 6, 2007 | 10:06 PM
Silverbullet00
Don't worry Nouman, aka FRC, I will post pics and the chart for you to laugh at!
Old Jul 7, 2007 | 02:18 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
I’ve never heard using 5th gear on a manual for a dyno run. I have only heard 4th. Is this something new or am I missing something?
Thanks,
Clayton from Las Vegas
Old Jul 7, 2007 | 02:29 AM
Bill Dearborn's Avatar
Bill Dearborn
Thanks,
Every dyno run I have had was in 4th.
Bill
Old Jul 7, 2007 | 04:21 AM
Blown 346's Avatar
Blown 346
Make sure thay have a fan in front of the car so it doesnt overheat. Also make sure they dont hit the brakes on the dyno, that could end up very bad.
Old Jul 7, 2007 | 04:27 AM
reactor2's Avatar
reactor2
Thanks,
OK, I've never been to the dyno but isn't 5th the closest gear to a 1:1 ratio with the engine?
Old Jul 7, 2007 | 04:28 AM
gpracer1's Avatar
gpracer1
4th is 1:1
5th and 6th are both overdrive
Gear Ratios
LS1/MM6 LS6/M12
1st Gear 2.66:1 2.97:1
2nd Gear 1.78:1 2.07:1
3rd Gear 1.30:1 1.43:1
4th Gear 1.00:1 1.00:1
5th Gear 0.74:1 0.84:1
6th Gear 0.50:1 0.56:1
Reverse 2.90:1 3.28:1
Old Jul 7, 2007 | 04:35 AM
Mr. Azrael's Avatar
Mr. Azrael
If you dyno your MN6/MN12 car in 5th you are going to get some low numbers...
Should be dynoed in 4th gear 1:1, 5th and 6th are OD gears.
Old Jul 10, 2007 | 10:43 AM
C5XTASY's Avatar
C5XTASY
Any other factors such as weight, amount of fuel, tire pressures, etc? I wouldn't expect any of that to matter on a dyno, but have heard of various methods to get higher numbers on a dyno, other than screwing with the software.
Ed
Old Jul 10, 2007 | 11:03 AM
Ryan L's Avatar
Ryan L
4th gear manual...1:1
To chassis dyno do's, don'ts
