Got CEL today
Old Jul 7, 2007 | 11:22 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Default Got CEL today
So I checked the code and deleted it.
Stayed away for a bit then came back. I deleted it again. Hasnt come back yet today.
The code is PCM P0430 H C.
So I looked 'er up and got this...P0430 TWC System Low Efficiency Bank 2.
Now I think it has something to do with the pass side coils, or plug wires or something? I took a quick look, everything looked ok.
Any ideas?
Thanks-In advance
Old Jul 7, 2007 | 11:29 PM
rws.1's Avatar
rws.1
are you running headers?
i believe the code is generally associated with high residual Hydrocarbon hitting the O2 sensor after the catalytic converter..... can happen with hi-flow cats
Either than our your cats are starting to get plugged....
Old Jul 7, 2007 | 11:32 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Yes, I do have headers ( and hi flow cats)
Old Jul 8, 2007 | 11:44 AM
grunz95's Avatar
grunz95
Any ideas?
Thanks-In advance
I was on the "Corvette Doctor" site and the code DTC PO420 OR PO430 came up with CATALYST SYSTEM LOW EFFICIENCY. That code did not have PCM in front of it, It had DTC is that the same thing? I'm just trying to learn the different codes.
Thanks,
Gary
Old Jul 10, 2007 | 04:04 AM
matuszynski's Avatar
matuszynski
o2 sims will solve your problem. try doing a search for member cbrf4i1, he has some o2 sims that will take care of your p430. i think i paid around $30 for a set.
update.....5k miles later, still no check engine light.
To Got CEL today
