Rear Axle Leak
Old Jul 11, 2007 | 10:31 AM
ALVETTE00's Avatar
ALVETTE00
Default Rear Axle Leak
So I've got a little leak from the left side of the axle...about 300 to fix it...anyone else have this issue?
Thanks,
-al
Old Jul 11, 2007 | 10:37 AM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default Yup
When I first had my C-5 convertible I would use the "traction control" button to deactivate the traction control and do broadies in parking lots like a zamboni! That was fun up until time I noticed an oil spot on the garage floor. Fortunately I bought the extended warranty and the dealer took care of the leak. No leaks since and no broadies either, I now have the Michelin Pilot Sports and they were $$$$$ Dinero Maximo anyway.
Old Jul 11, 2007 | 12:20 PM
Had mine leak three times. GM put in new seals each time and looks like the third time was a charm.
Old Jul 11, 2007 | 12:56 PM
Kanon's Avatar
Kanon
Thanks,
-al
Or you can fix it yourself for about $30 if you have the tools...
http://www.cajundude.com/outputshaftseal.htm
worked for me.
Old Jul 11, 2007 | 01:37 PM
ALVETTE00's Avatar
ALVETTE00
Wow...thanks for that info!!!
How long does this take to do?
-al
Old Jul 11, 2007 | 01:54 PM
bilx013's Avatar
bilx013
St. Jude Donor '12
Had the leak as well....
Old Jul 11, 2007 | 02:10 PM
aaavette's Avatar
aaavette
Also had the leak, but dealer fixed under warranty. They kept the car all day, but doubt it is an 8 hour job.
Old Jul 11, 2007 | 02:20 PM
rrichar2591's Avatar
rrichar2591
Just had mine done for about the 4th time. Each side now has needed it. If you have someone do it, make sure you get a warranty for the work. Chances are you may have to redo it. My total bill was 335.00 but extended warranty took care of most of it. Good luck.
Old Jul 11, 2007 | 06:23 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
GMPP covered the cost.
Old Jul 11, 2007 | 06:39 PM
franny40's Avatar
franny40
i was quoted $ 475.
To Rear Axle Leak
