[Z06] Confused by HP
Callaway Honker and TB
American Racing LT's (no cat's)
Comp Cam 224 / 230 / 112
Professional Dyno Tune
I question the final numbers as it seems all of the other cam only cars in this forum are running 420 - 430rwhp. The tune was performed on a Mustang Dyno and it was explained to me that the Mustang will provide more realistic numbers than a DynoJet.
Your thoughts on this would be much appreciated.
I do have the "heavy" imitation C6 Z06 wheels. Could these be holding the HP back that much?
Thanks in advance for the input.
You are just a little on the lower side but you didn't say if that is SAE corrected. Mustang dyno's do have a reputation of being about 15% lower than a Dynojet but frankly I don't know if that has ever been empirically proven. If you use a well maintained and calibrated dyno it should be very accurate.
Now you mention heavy wheels and rotating mass is a real killer for horsepower. You also don't mention anything about your heads and that is good for another 15 to 25rwhp. So if you have the stock heads your number is right in the ball park.
Yeah, mine with H/C and FAST only did 436 on a Mustang, maybe the same one as above. Vancouver, WA. 'Course the clutch was slipping, and after one run was stuck to the floor.
Also, how was the ambient when you ran it? Temp/Humidity/Above Sea Level/etc...
Then again, the cam size & tune play a big part with the numbers too, but regardless, I wouldn't sweat it too much...
A mustang dyno is a better tuning tool than a dynojet because it adds more load. besides that you will only know how your car compares to those others by going to the track and seeing your mph.
Just for comparisons sake I do have a c4 but my 388 dynoed 488 rwhp on mustang dyno and did 547 rwhp on a dynojet. somewhat in line with the 15% corection between the two dyno types.
Ask one of those 430rwhp cars to give you his 1/4 MPH from a track.
Do you know what yours is?
If you post a datalog, we can estimate your A/F through the RPM range.
A better number to work with is average hp under the power curve.
If you have two dyno curves, I can help check this for you.
Over the winter, I did a H/C package and wanted to get the car on a dyno and tuned. The only remaining local shop options were Mustang Dynos.
Here is my history of mods and dyno testing
dynojet numbers
Stock 2002 Z06 - 350 rwhp 346 rwtq
with LG LT, hi-flow cats, vararam - 375 rwhp 367 rwtq
best ET 12.11 @116 DA 2900
Mustang Dyno - 2 weeks ago
same mods as above, plus AFR 205 59cc heads, G5X2 cam, UD pulley, 30lb SVO injectors - 412 rwhp 352 rwtq
The dyno operator stated he has seen a 12 - 15 % difference in his numbers vs. a dynojet. I know the only numbers that count are from the track. But needless to say after seeing the results, I had to find a dynojet just for argument sake.
Dynojet - last week
I found a speedshop about 1 1/2 hours away from my home. The results were what you usally see posted.
The car made 459 rwhp 424 rwtq
Moral of the story, you can drive yourself crazy trying to compare numbers. I fell victim to it as I had to find a dynojet "just to see" what happened with the results. Bottom line for me, I want to see what the car runs and picks up in ET/MPH if I can drive it right.
take care and good luck.
Looks like its safe to say my Z is within the "norm" specs and not a weakling. I have a hard copy of the run that I'll try to post. Maybe it will bring additional information. I would like to know what BADMFR knows about the magic 400hp bolt on's.
It's been suggested that a 90/90 set up sould be next which would push it over the 400hp mark and heads should follow.
...end threadjack
, the 70rwhp came from a cam and a tune from ECS. I already had slp longtube headers, slp high flow cats and slp's 3" exhaust. The base line dyno at ecs was 363, after cam and tune 430, so technically 67rwhp, stock untouched heads. Sorry for the hijack reply.
dynojet numbers
Dynojet - last week
The track is a great tool to see the impact of your mods. Bad part, is as yuo get better, your times may get a better improvemnt then your ets.
BLUFF, when I added LG Pro Lts and a tune, my Ets dropped a ton (12.33 to 11.89). Hell yea
Added a good clutch, small blower cam, and some bolts ons to keep it together (brace, shafts, water pump...) and it dropped down to 11.5s. 407 ish rwhp
Added a bigger NA cam, heads, fast 90, 90 tb... couple sets of 390s later, drag pack, stage V tranny, lots more ect... 460 rwhp, but only improved to 11.4s
Funny part is my short times from 11.5 to 11.4 have dropped from 1.59 to 1.46, but I did change tracks. I am down a few MPH here @ Jackson compared to NAM, and I am hooking up like crazy, which might be dropping trap speed some, but damn, I wish I could get that .2 in ET with the better shorts.BLUFF dynos are a great tuning tool, and a good way to compare how things should work. Drive it and see what realy happens and good luck!
Dave
Now, much more mods
