97-98 keyless entry reprogram..........
Old Jul 12, 2007 | 09:58 AM
rrhvette's Avatar
rrhvette
Default 97-98 keyless entry reprogram..........
Good morning.......I did search for this issue but it comes up with noi matches.........Could anybody tell me how to reset/reprogram the keyfobs.......I changed batteries in both, held the lock & unlock buttons down doesn't make any difference.........Any help would be appreciated.....
Old Jul 12, 2007 | 10:00 AM
VinnyT's Avatar
VinnyT
1-Turn the ignition to RUN
2-Turn the radio off
3-Press the RESET button in order to clear any IPC warning messages
4-Press the Option button on the DIC until the IPC display is blank in order to enter the program mode
5-Press and hold the Reset button for 3 seconds
6-Press the option button until FOB Training message is displayed
7-Press the Reset button in order to begin the programming sequence.
8-Simultaneously press and hold the lock an unlock buttons on the first transmitter for 12 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this step for each transmitter.
Old Jul 12, 2007 | 10:10 AM
rrhvette's Avatar
rrhvette
Thanks VinnyT.......I appreciate the info, that is exactly what I needed..........
Old Jul 12, 2007 | 10:31 AM
Zenak's Avatar
Zenak
Terminal Vette Addict
Corvette keyless remote programming instructions:
**NOTE** you must reprogram both the NEW & OLD FOB. Reprogramming the new one leaves your old one inoperable.
To match transmitters to your vehicle:
1. Turn the ignition key to the ON position.
2. Clear any warning messages on the Driver Information Center (DIC) by pressing the RESET button.
3. Press the OPTIONS button on the DIC several times until the blank page is displayed, then press and hold the RESET button for two seconds.
4. When the message FOB TRAINING is displayed, push the RESET button once.
The message HOLD LK+UNLK 1ST FOB will be displayed.
5. Press and hold the LOCK and UNLOCK buttons on the transmitter simultaneously for 15 seconds.
6. When a transmitter is learned, the DIC will display FOB LEARNED and then prompt you to learn the nest transmitter.
7. Repeat steps 5 and 6 for each additional transmitter.
8. Remove the key from the ignition.
The programming mode will shut off if:
You don't program any transmitters for two minutes
You take the key out of the ignition.
You have programmed three transmitters.
Old Feb 18, 2011 | 04:58 PM
malligood55's Avatar
malligood55
I have followed thsi but the FOB training message does not appear. My car is a 99 coupe.
Old Feb 18, 2011 | 05:13 PM
HG's Avatar
HG
Hope this is not a dumb question, did you check the owners manual.
If youdon't check here
http://www.corvetteactioncenter.com/...999/index.html
Old Feb 18, 2011 | 06:19 PM
65GGvert's Avatar
65GGvert
You must have done a horrible job of searching.
Old Feb 19, 2011 | 12:11 AM
malligood55
I think I did ok searching and reading the manual. It came up but I think my fob must be bad. Thanks for you input.
To 97-98 keyless entry reprogram..........
