Height to install BSM's?
Old Jul 12, 2007 | 04:47 PM
PaceThis's Avatar
PaceThis
Default Height to install BSM's?
Hi guys,
A local friend of mine just bought an 03 Vert and wishes for me to install the Body Side Moldings on his ride. I don't mind doing it, but don't know the height measurements to install them from.
If someone has some measurements available, I'd appreciate it
Thanks,
Josh
Old Jul 12, 2007 | 05:04 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
No exact measurements but from the photos you can see they start in the center of the fender opening and rise about 2 inches at the rear end of the molding. Problem with measurements is that there is no perfect point to measure from, no sharp edges. You can't measure from the ground since each car may sit just a little differently.
Good Luck
Old Jul 13, 2007 | 09:47 AM
PaceThis's Avatar
PaceThis
That may work, I can probably get it pretty close from the photos. If you were to measure it, it's probably easiest to get a measurement from the bottom of the door.
Thanks!
Josh
Old Jul 13, 2007 | 10:02 AM
Z06HPISFUN's Avatar
Z06HPISFUN
St. Jude Donor '07
Originally Posted by PaceThis
Hi guys,
Thanks,
Josh
This should do it.
(From the GM Service Manual)
Top of fender to the top of molding is 335mm (13.2 in).
Bottom of key-hole opening to top of molding is 195mm (7.8 in).
Front edge of molding is positioned 5mm (0.20 in) rearward of the front edge of the door
Old Jul 13, 2007 | 10:55 AM
PaceThis's Avatar
PaceThis
That's exactly what I was looking for Thanks to you both
Between the photos and measurements, we can get it done perfectly
Old Jul 13, 2007 | 11:56 AM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
Let me be the first to say it.......DON'T DO IT.
Old Jul 13, 2007 | 12:55 PM
CH.CRAFT's Avatar
CH.CRAFT
Default Bsm's
I TOOK MINE OFF, THE BODY LINES LOOK BETTER WITHOUT, IMHO.
Old Jul 13, 2007 | 03:30 PM
PaceThis's Avatar
PaceThis
To each their own...for me, it really depends on the color. Some look better with, and some better without. But, if you're not in the habit of parking carefully, all will look better with the BSM's and w/o chips in the paint from other people's doors...that is why they were designed, after all.
Old Jul 13, 2007 | 07:53 PM
Singer Island C5's Avatar
Singer Island C5
Default Is he sure about this?
Amazingly, a recent poll here on CF found that about 50% of respondents approve of BSM. Is your customer aware of the fact that a great many true Corvette enthusiasts find BSM to be inconsistent with the C5's classic lines. What would Zora Duntov have said about them. Dick Guldstrand is still around, let's ask him about questionable looking dead weight carried high! Hey, I'ts his ride and God bless him whatever he decides. If he wonders if some people snicker when they see BSM; ABSOLUTELY!
Old Jul 13, 2007 | 07:58 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I remember the poll. I like mine, but if I didn't have them I wouldn't complain either. Sure, it is a matter of taste, take me for insistance, I HATE POPUP HEADLIGHTS, so I guess I am never going to be a true CORVETTE lover...NOT!
Old Jul 25, 2007 | 08:40 AM
VetteFTW's Avatar
VetteFTW
Mine is a DD, so they are an absolute necessity. Like today, I had to park in a space that would be small even for a Civic. Luckily, I'm not very wide or i wouldn't have been able to get out of the car.
Moral of the story for me really is get to work earlier and get the good parking spots! However, I still like my BSMs they look cool to me.
Old Jul 25, 2007 | 08:46 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
Old Jul 25, 2007 | 10:38 AM
KCJeff's Avatar
KCJeff
Is your customer aware of the fact that a great many true Corvette enthusiasts find BSM to be inconsistent with the C5's classic lines. If he wonders if some people snicker when they see BSM; ABSOLUTELY!
Who cares what others think? Certainly not me. I don't know anyone who purchased their Corvette to please others. The original poster asked for technical assistance on installation, not personal opinions on corvette styling. I guess there will always be people who are simply unable to prevent themselves from expressing unsolicited negative opinions.
Old Jul 25, 2007 | 10:54 AM
65GGvert's Avatar
65GGvert
The original question was at what height, not should he do it (thank God). That horse has been beaten so badly, the stick is a toothpick now.
Old Sep 5, 2007 | 02:32 PM
KeyoRacing's Avatar
KeyoRacing
I have a Mag Red 99 and I don't have them but I DO like them SOOOOOO if anyone has a set of Mag Reds you don't want I'd love to take them off your hands!
Old Sep 5, 2007 | 04:02 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I also added mine on. I found that a used set of BSMs does not keep the contour of the body well. So now I have them off, Again.
To Height to install BSM's?
