Need Help!!!
Old Jul 13, 2007 | 09:20 AM
2007VRZ51's Avatar
2007VRZ51
Default Need Help!!!
I WANT TO PUT ON A LICENSE PLATE FRAME ON MY 01 VERT BUT THE BLACK COVER SURROUNDING THE LICENSE PLATE IS ALLREADY THERE-HOW CAN I TAKE THIS OFF? THANKS
Old Jul 13, 2007 | 09:36 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Unscrew it. If you don't see screws, then pop out the hole covers, in the black frame, and they should be there.
Old Jul 13, 2007 | 09:39 AM
2007VRZ51's Avatar
2007VRZ51
you mean behind the lic. plate?
Old Jul 13, 2007 | 09:49 AM
1stvette@60's Avatar
1stvette@60
St. Jude Donor '07
There are some notches on the inside of the surround, IIRC. Put a flat blade screwdriver in the notches and pry out. There are barbed tabs on the back of the surround that snap into slots. When you are finished, snap it back on.
Old Jul 13, 2007 | 09:54 AM
sneakelman's Avatar
sneakelman
See you DO learn something everyday. The one I saw on my buddies 02 vert was screwed on. Think it was aftermarket maybe? Or was there a change from 01 to 02?
Old Jul 13, 2007 | 10:19 AM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Look closely at the photo. You'll see two "slots" on each side. That is where you'l pry (lightly) to get the old one off.
I think you'll have trouble getting a custome surround that fills in properly. I tried it with an NCM surround and it looked
BTW, the reason the lights look weird is because the left is one of Richards' (C5Vette) tower LEDs and the right is the stock bulb. Both in Richards' Smoked Adjure housing.
To Need Help!!!
