Clear Corner Question
Old Jul 13, 2007 | 05:48 PM
Wicked_Z06's Avatar
Wicked_Z06
Default Clear Corner Question
I must be stupid. I can't seem to figure out how to install these? Do I have to go under the car or what? Man everything is so different from my Camaro... haha..
Anyway, help would be nice. I tried the search, but didn't come up with any help.
-Kyle
Old Jul 13, 2007 | 05:57 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Yes, there is an access panel just below the brake cooling ducts. take that off, remove one screw and one bolt, and one spring. Change fixture, reverse process.
As it should be
Old Jul 13, 2007 | 05:59 PM
rcs128's Avatar
rcs128
Yup, from under the car. You remove two plastic panels under the bumper (maybe 5-7 little bolts each side) and then you can just reach up and find the 2 bolts that hold each lamp in. THere's also a tension spring at the top.
It's pretty easy. Probably take you 45 minutes to do the first one and then 15 minutes to do the other.
Old Jul 13, 2007 | 06:07 PM
Wicked_Z06's Avatar
Wicked_Z06
Thanks for the quick info guys!
Old Jul 13, 2007 | 06:13 PM
jdmvette's Avatar
jdmvette
Night Owl for life
you can also raise the lights manually, remove the bezel, reach down and remove from there.
Old Jul 13, 2007 | 06:22 PM
beav626's Avatar
beav626
underneath with the car on a lift is easiest...
Old Jul 13, 2007 | 09:14 PM
Yr6's Avatar
Yr6
Nice Avatar, any higher res pics
Old Jul 16, 2007 | 12:15 AM
Wicked_Z06's Avatar
Wicked_Z06
Thanks!
http://forums.corvetteforum.com/show...post1561011650
Old Jul 16, 2007 | 09:22 PM
Yr6's Avatar
Yr6
To Clear Corner Question
