So there I am cruising along and I notice the fuel reading on my HUD is not indicated. RPM and speed is OK. I generally have the fuel, speed, and RPM display chosen. Unsure how long it had been off and I do watch the display freqently for speed.
So now I am paying attention to the display and about 15 seconds later, the fuel registers again. It just sort of rolled up from nothing to 3/4 which is what the gauge said also. Later, I noticed when I started the car, the display came up a couple seconds after everything else was up. It seemed to be fine after that. It's an 04' Coupe. Any suggestions or worries?
mine does that sometimes where everything is dimly lit up. it will do it for a minute or so and then go away. mine only does it like once every couple of months or so. not sure why though.
