[Z06] Stability Control / ABS System Messages
Jul 16, 2007 | 08:48 AM
Are there any simple things I can check that may cause these error messages to come up? I hesitate bringing any vehicle to a dealer unless absolutely necessary.
Jul 16, 2007 | 09:39 AM
Look at the FAQ sticky at the top, more specifically post #28, where is describes how to read the DIC codes and what the codes mean. Then you can search on that particular code to see if anyone else has had the same issue...
Jul 16, 2007 | 11:28 AM
Bad EBCM. Seems every single one of these cars needs one replaced eventually.
Jul 16, 2007 | 12:47 PM
Mine is on the fritz. I'll be pulling it and sending it to absfixer.com soon.
Jul 16, 2007 | 12:49 PM
Check here:
http://forums.corvetteforum.com/show...action+control
I just sent an email to the guy in post 3.
To check your codes
While
holding "Options" button hit "FUEL" Button 4 times
Get a pen and paper ready to write down codes.
1214 is a definate sign
also
1287
1288
Jul 16, 2007 | 05:39 PM
EBCM issue if you are under warranty you are lucky if not you need to purchase a new one.
I feel the pain I have been there just 2 months ago.
Jul 17, 2007 | 03:15 PM
I got the messages last week (2003 Z06). I added brake fluid. Messages went away.
This was usually ABS the fix with my 1995. Maybe it works for the new ones too.
I don't know if the newer cars have a separate code for low fluid.
Jul 17, 2007 | 03:17 PM
C1233 is the code I am reading
Is there an easy way to check the RF Wheel Speed Circuit?
By the way.... thanks to everyone that has responded.
Rich
