Has anyone painted their calipers blue and can post a pic.
I do not have a pics, but a good way of doing it. This method will last and you will be able to color match your factory color!
1. Buy a can or two of spray touch up in your factory color.
2. Clean everything very well
3. Give the calipers two coats of high temp primer (grey is fine)
4. Give the calipers three coats of the factory color
5. Seal the factory color with three coast of high temp clear.
This basically allows you to match your factory color or paint your calipers any color you want even if the paint does not come in high temp. The paint will not fall/fade/evaporate off as it is sealed with the high temp clear. Good luck...
"Let me try...LT"
Thanks LT, thats what I was looking for. Did you use heat paint or a caliper painting kit. I was thinking of going with blue calipers and the blue tipped chrome lug nuts by McGard.
"Let me try...LT"
Sorry to take so long to reply. Previous owner painted them. He told me what he used. But, I forgot. I may have it written down somewhere.
