OEM Air Dam? When Lowered!
Old Jul 16, 2007 | 11:02 PM
sdspeed's Avatar
sdspeed
Default OEM Air Dam? When Lowered!
I'm lowering the front, what does everyone do about the stock air dam? Remove it, trim it? Will the car overheat without it?
Or do you just let it drag until it's not in the way anymore???
Old Jul 16, 2007 | 11:11 PM
lordbones's Avatar
lordbones
Old Jul 16, 2007 | 11:19 PM
Rick Radcliffe's Avatar
Rick Radcliffe
Keep it and let it drag.
My air dam has about half an inch of clearance before I get in the car. Probably touching when I am driving.
No air dam means overheating for sure.
The replacement is under $100 for all three pieces. I have my doubts you will ever need to buy them.
BTW....watch out for anything bigger than 2 inches. Rocks, road kill, etc. They catch underneath the car. Don't ask me how I know.
Rad
Old Jul 17, 2007 | 12:18 AM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Since lowering the air dam has taken on a dual role. Not only does it direct air to the radiator, it also sounds the alarm when the ground is getting too close to the chin. Leave it on and listen for the "alarm."
Old Jul 17, 2007 | 12:33 AM
dw99vette's Avatar
dw99vette
From: 15 miles south from the Raisin Capitol of the World Caifornia
Scrape to fit.
Old Jul 17, 2007 | 06:18 AM
I'd just leave it on - it's cheap to replace should it get banged up.
Old Jul 17, 2007 | 06:37 AM
Mr. Azrael's Avatar
Mr. Azrael
It's spring loaded and knows when to move out of the way... although the two rubber side pieces are scrape to fit...
BTW, just be careful if you try to clean it up by hand after a little scrape fitting, since the last time I pulled a piece off I drug my knuckles across the ground and took off a pound of flesh for the automotive gods...
Old Jul 17, 2007 | 11:21 AM
BanditSRT's Avatar
BanditSRT
If you remove the air dam you WON'T overheat. I ran without one for a year. Temps didn't seem to change much if any. I recently put it back on and my air conditioner seems to work better but my coolant temp hasn't changed.
Old Jul 17, 2007 | 11:24 AM
02MillenniumVette's Avatar
02MillenniumVette
You will learn to go into driveways and entrances at a certain angle to keep it from scraping.
To OEM Air Dam? When Lowered!
