Rear drum grinding??????
Old Jul 18, 2007 | 09:49 AM
04DevilR1's Avatar
04DevilR1
Default Rear drum grinding??????
has this happened to anyone else. when im driving i can hear a pulsing grinding noise coming from the rear brakes that speeds up as i go faster. If i pull the e-brake up a little bit it turns into a constant grinding noise. does anyone know if i need new rotors or a new drum lining??? it looks like i have plenty of lining left but i dont know. maybe i need to get the rotors resurfaced? thanks!!!
Old Jul 18, 2007 | 10:04 AM
Warnberg
Guest
Posts: n/a
First off they are rotors not drum brakes. I would check the rear brake pads, usually there is a wear indicator in the form of a metal finger that sticks out and makes contact with the rotor to make a metallic noise indicating the pads are worn. If it has gone that far you will need to replace the rear brake pads and have the rotors resurfaced (have them turned at a machine shop).
If it's pulsing, that usually indicates that the rear rotor is warped and can either be turned or may need to be replaced.
Good Luck
Dave
Old Jul 18, 2007 | 10:10 AM
1-BAD-C5's Avatar
1-BAD-C5
Drums and rotors both in the rear,.. damn that car must stop on a dime and pick that sh*t right up! haha
just kidding there pads / and rotors,... rotors wont produce a sound they will just get warped and cause vibration. change the pads and resurface the rotors at the same time, so you have a fresh slab of steel to start those new pads on ... good luck!
Old Jul 18, 2007 | 10:17 AM
Busarider's Avatar
Busarider
Rotors will make plenty of noise if a caliper is bad. If the piston in the caliper is not fully retracting after use (hanging up), it will constantly push the pad into the rotor.
Go get the brakes checked out. If you are hearing a constant grinding, chances are the rotor is already junk.
My guess without seeing it is bad caliper. Fix will be rotor, pads, caliper.
Old Jul 18, 2007 | 10:19 AM
04DevilR1's Avatar
04DevilR1
alright maybe i didnt use the right terminology. but there are two parts to the rotor and two sets of pads. There are brake pads that put pressure on the outsides of the disc when you brake....but there is also a different set of *shoes* that act like a drum brake when u pull the e-brake. These shoes rub on the inside of the rotor (its a circle) and it expands when u pull the e-brake. the e-brake doesnt work the rear calipers. the sound is not coming from the brake pads its coming from the shoes rubbing against the inside part of the rotor(the e-brake)
Old Jul 18, 2007 | 10:36 AM
ZeroHer0's Avatar
ZeroHer0
Been driving with the e-brake on?!? Sounds like you need to adjust them.
Old Jul 18, 2007 | 10:38 AM
04DevilR1's Avatar
04DevilR1
naw dude i havent... but i dont need to ajdust them. they are just rubbing in one spot (the pulse grinding sound) when the e-brake is down.
Old Jul 18, 2007 | 10:42 AM
Warnberg
Guest
Posts: n/a
The pads for the e-brake are they free to move in and out OK? No binding of the cable anywhere? What does the inside of the drum look like (where the e-brake pads make contact) any rough or rusty patches?
Dave
Old Jul 18, 2007 | 10:51 AM
Busarider's Avatar
Busarider
My Expedition had the same problem time to time (had the same ebrake set up)I just got up to about 60 mph and put the ebrake on about 1/2 strength for a few seconds (keep button in so brake doesnt click to engage). It would remove the built up crap inside the drum/rotor. Maybe someone more familiar with the corvette set up will chime in if this "fix" works for the vettes also. If that doesnt work its possible the wheel cylinder is hanging up, not fully releasing the pads.
Old Jul 18, 2007 | 12:27 PM
Jet-Jock's Avatar
Jet-Jock
Looking through the Factory Service Manual it would confirm you are using the correct terminology. Regardless of whether the rest of the industry calls them pads or rotors, for service they are known as shoes and drums.
Old Jul 18, 2007 | 05:03 PM
00247's Avatar
00247
My Silverado will do the same thing. It is a build up of crud and and the rotor was getting rusty. Clean it up and fry it once in a while. should be good to go. Funny how the mechanically challenged were so quick to beat you up.
To Rear drum grinding??????
