[Z06] C5 Fan Trick
Old Jul 18, 2007 | 01:51 PM
Ranger's Avatar
Ranger
Default C5 Fan Trick
Get a chance to hot-lap at the drag strip? Hate paying that horsepower penalty when the coolant temp soars? There is a work-around short of a fan switch or tuning the PCM.
All it take is a 6 inch piece of wire and a couple minutes to do the set up the first time. After that about two minutes each time you go to the track. Helpful in the summertime too; keeps the engine temps in the range for good power.
I put up a page at my site with a how-to for turning on the fans without tuning or a switch.
Here is a link: C5 Fan Trick.
Ranger
Old Jul 18, 2007 | 01:59 PM
Bigstik's Avatar
Bigstik
Can this trick be used if I am just driving the car around town and there are a number of long traffic lights to wait thru? I know that it is not neccessary in the winter, but it gets pretty hot during the summer months in the ATL.
Awesome write up by the way. The pictures REALLY help. thanx
BonestockZ06's Avatar
BonestockZ06
Thanks Ranger, This is a must have for me, especially at E-town were it takes you ten minutes from the pit to the burnout box once you start moving.
Something that just came to mind. What do you think about adding a automotive 12v say 15amp toggle and then just flip it on whenever your at the track?
Old Jul 18, 2007 | 02:06 PM
Ranger's Avatar
Ranger
The C5 Fan Trick will turn on the low-speed fans, for whatever purpose, and keep them running until the trick is removed.
But got to be honest with you Bigstik, those 220-240 temps in traffic don't do any harm. They do matter at the drag strip where measured acceleration in the name of the game and the penalty for the high temps is .20-.40 seconds in the quarter-mile.
And thanks for the kind words.
Ranger
Old Jul 18, 2007 | 02:14 PM
Ranger's Avatar
Ranger
Originally Posted by BonestockZ06
...What do you think about adding a automotive 12v say 15amp toggle and then just flip it on whenever your at the track?
I refrained from that approach. Didn't want to run a risk of needing to explain it's purpose to a tech or district rep should a warranty claim be hanging in the balance. The Fan Trick is clean and leaves no tell-tale sign.
Plus I only need to control the fans at the track. Two minutes to turn them on. Part of the track ritual, if conditions warrant.
When you return home from the track at the end of the day and shut the motor off in the garage, you can hear the fans still running; a reminder to remove the Trick and stow it away in the glovebox.
Ranger
Old Jul 18, 2007 | 02:20 PM
BonestockZ06
Ranger
I see your point. It was just a thought, I guess it would still work for those without warranty issues. BTW, great write up, I already stored my wire in the GB.. he he..
Old Jul 18, 2007 | 02:28 PM
MUKAK's Avatar
MUKAK
thnks
Old Jul 18, 2007 | 04:14 PM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
Thanks. You da man!
Old Jul 18, 2007 | 04:26 PM
bernrex's Avatar
bernrex
Thank U .... who doesn't like to 'hot lap' when traffic is low... and not pay HP penalty for the rapidfire enjoyment of the sport.
I'd bet this will also work on C5 base cars. Will check fuse box and see if it is same as on Z's.
Old Jul 18, 2007 | 04:30 PM
Ranger's Avatar
Ranger
Hi bernrex,
Your sensing is correct.
I've checked the owners manual diagrams for 1997-2004 and the configuration of the Relay box appears identical for all MY C5s.
Ranger
Old Jul 18, 2007 | 06:10 PM
bernrex's Avatar
bernrex
Hi bernrex,
Ranger
C5 hotlappers .....
Old Jul 18, 2007 | 07:24 PM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Hey John,
I see you finally got the pics up. They turned out pretty good. Don
Old Jul 18, 2007 | 07:32 PM
Ranger's Avatar
Ranger
Originally Posted by dwjz06
Hey John,
Thanks for your help, sir.
Ranger
Old Jul 18, 2007 | 07:53 PM
dwjz06's Avatar
dwjz06
Dogface
Ranger
Anytime sir.
Old Jul 19, 2007 | 01:31 AM
striper's Avatar
striper
Thanks, Ranger. Fan wire trick sounds like a neat idea. I will be trying it on my car and if satisfied, I'll probably run a wire to a switch in my interior, mostly for convenience. Just because 240 degrees in traffic is okay, that doesn't mean I feel comfortable seeing temps that high. I've got a street rod with a hot rod Chevy motor in it. In 95 degree weather, sitting in traffic with the a/c on, it'll idle forever at 185-190 degrees.
Old Jul 19, 2007 | 09:55 AM
HP_Addict's Avatar
HP_Addict
Here is an alternative for a permanent solution. You install a toggle switch in the car, then wire a relay inline with the existing fan relay. the new relay keeps the stock operation and prevents the PCM from throwing codes. However this system only turns on the upper fan in high speed mod. I devised this system several years ago and it works great.
Old Jul 19, 2007 | 11:08 AM
Ranger's Avatar
Ranger
I'm sure that members looking for a permanent solution, but uncomfortable reading and interpreting a wiring diagram, would appreciate any pictures you may be willing to post of:
(1) the actual wire splice/connections you made.
(2) wire routing
(3) penetration through the firewall
(4) switch location and capacity, etc
If posting images presents a problem, I'll be happy to host them for you.
TIA,
Ranger
To C5 Fan Trick
Old Jul 19, 2007 | 11:11 AM
401K Z06's Avatar
401K Z06
Ranger
Ranger, will the fans ramp to high speed if called for, or are they locked in at low speed?
Thanks,
Rich
Old Jul 19, 2007 | 11:18 AM
Ranger's Avatar
Ranger
Thanks,
Rich
Hi 401K Z06,
Using the Fan Trick, the fans remain in low-speed mode. For work at the drag strip, low-speed is sufficient.
I didn't use the Trick on the street. There, the factory turn-on points for low and high meet my needs.
Ranger
Old Jul 20, 2007 | 12:06 AM
ZeeOSix's Avatar
ZeeOSix
Just turn on the AC, which turns the fans on all the time. Helps keep the coolant temps (and the driver) cooler in hot city driving.
