[Z06] Pissed!!!
Old Jul 19, 2007 | 02:43 AM
yellow 02 Z06's Avatar
yellow 02 Z06
Default Pissed!!!
Today i went to the mall. Went in, came out, got in my car and found out the hard way that the column lock problem that plagues corvettes had not been taken car of by the previous owner of the car . So I had to get a flatbed tow-truck to drag my car out of the parking spot then load it up and take it to chevy. It was 6pm so the service department was closed and I had to leave the keys in the night drop-box. I am very pissed because I am now without a car, even though I should hopefully have it back in the morning since this is a recall problem. It was just embarassing having to have my car towed out of the mall parking lot.
Old Jul 19, 2007 | 02:49 AM
pb24dagrk's Avatar
pb24dagrk
Yea it is pretty embarassing :o
when I first installed my short shifter, one of the bolts came loose and jammed the shifter, not letting me get it out of neutral...I didn't have any tools on me to fix it, so I had to call the flat bed
I even had a ricer rev at me as he drove by while i was standing on the side watching my car get put on the flat bed
Old Jul 19, 2007 | 02:57 AM
yellow 02 Z06
yeah i had some guy in a z71 pickup rev it up at me like i was suppose to care
Old Jul 19, 2007 | 05:26 AM
M6 Vetter's Avatar
M6 Vetter
Sorry, but why don't you just buy the CLB kit, instead of taking it to the dealer... JMO
Old Jul 19, 2007 | 07:15 AM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
,And if you think a previous owner has installed a clb but you're not sure, just see if the steering wheel turns with the key off.
Old Jul 19, 2007 | 09:04 AM
Bigstik's Avatar
Bigstik
after the clb fix, is the steering wheel supposed to turn with the key off??
Old Jul 19, 2007 | 09:16 AM
yellow 02 Z06
For one i dont have time to wait on ordering a clb kit. I couldnt leave the car in the parking lot overnight unless i wanted broken windows and slashed tires, and no the wheel wouldnt turn no matter what. To add to it, i just talked to the dealership and they said that the motor column lock motors itself was locked up and it wasnt covered under the recall and it cost $588. Now Im really pissed. Luckily I have an extended warranty and it should be covered.
Old Jul 19, 2007 | 11:04 AM
BonestockZ06's Avatar
BonestockZ06
Now that you mentioned it, I got curious and checked mine. Without the key in the ignition, I'm still able to turn the wheel to either side. Does this means that I have the the column lock issued resolved in the past? I just bought it a couple of months ago, so I don't know whats been done to it.
Old Jul 19, 2007 | 11:21 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
You could have saved yourself. Here's how to unlock it:
When the column is locked you can still turn the wheel side to side against the locks mayne 1/4" to 1/2".
When you turn the key to the "on" position (not starting it) it sends the signal to unlock the column
If you turn the key "on" with your right hand all while slaming the wheel left and right against the locks w/ your left hand it will pop loose.
Worked form me twice, and multiple buddies who've called me asking what to do when the column locks.
Old Jul 19, 2007 | 11:44 AM
sothpaw2's Avatar
sothpaw2
Yes. It is resolved for you.
Old Jul 19, 2007 | 11:52 AM
BonestockZ06
cool Thats one less thing to worry about.... Yellow o2 z06, I'm sorry to hear about your situation, I hope you get it resolved in the least expensive way possible. Now adays everything is money money money..
Old Jul 19, 2007 | 01:59 PM
SFCA1968's Avatar
SFCA1968
Did they fix the col. lock prob before the 05's came out?
Old Jul 19, 2007 | 02:49 PM
The Wanderer's Avatar
The Wanderer
Funny that this is the 2nd post in the past day that dealer said it is the column lock motor that is bad. I wonder if this is the latest scam some dealers are employing to generate more $$$$$'s.
Also, wasn't there another recall that installed a plate to blocked the lock from even engaging, because the original recall didn't work?
Old Jul 19, 2007 | 03:08 PM
nickolbag's Avatar
nickolbag
Why do so many people ignore this issue until it happens?
Old Jul 19, 2007 | 03:16 PM
overBlown's Avatar
overBlown
good question especially because it is a well know issue. out of site out of mind i suppose.
Old Jul 19, 2007 | 03:29 PM
pb24dagrk's Avatar
pb24dagrk
was this fixed for '04's?
Old Jul 19, 2007 | 03:49 PM
nickolbag's Avatar
nickolbag
Here you go. http://forums.corvetteforum.com/show....php?t=1015483
To Pissed!!!
Old Jul 19, 2007 | 03:53 PM
HammerZ06's Avatar
HammerZ06
4th Gear
My ignition cylinder went on my 03. Luckily it was in my garage, but I could not even get the key in or turn the wheel.
Anyone else had this issue
Old Jul 19, 2007 | 06:59 PM
jbauch357's Avatar
jbauch357
because it's not bothering them until it actually breaks... "it won't happen to me" syndrome...
Old Jul 19, 2007 | 07:11 PM
MikeP's Avatar
MikeP
It also effected 04 also. I had mine done late of o4. No problems ever noted prior or after CLB was accomplished by stellership.
Mike
