Need help to locate a part
Old Jul 19, 2007 | 08:30 AM
Robertelarkin's Avatar
Robertelarkin
Default Need help to locate a part
There is a small part that I just discovered missing. It is an interior trim piece. It snaps in behind the door handle (passenger side) to hide the adjustment screws in the door. Can you point me in the right direction.
Old Jul 19, 2007 | 09:02 AM
Secret237's Avatar
Secret237
Should be able to get it at the Chevy Dealer, shouldn't cost too much, $10.00 or so .... ( read at least $25.00 )
Old Jul 19, 2007 | 09:42 AM
LMB-Z's Avatar
LMB-Z
Both of mine were missing when I purchased my car. Went to the local dealership, had to order them. Took a couple of days, can't remember how much they were. Sorry.
Old Jul 19, 2007 | 09:52 AM
Robertelarkin
Default Thanks
I was hoping to avoid the stealers.........I mean dealers, and find somewhere on line, but I will go to the dealers and check them out, ooh , I just thought of something before the dealer, I will check a shop called "Just Corvettes"........Thanks
Old Jul 19, 2007 | 11:02 AM
Robertelarkin
Default Found a source
I talked with "Just Corvettes" and they recently had a run on "door handle bezel pieces" they said there may be a "bezel thief" on the loose..........I talked to the dealer, they also were out, but to order is $17.00 plus tax and shipping.
Old Jul 19, 2007 | 11:08 AM
rickko's Avatar
rickko
Did you try gmpartshouse.com?
All you need to know is the part number.
Old Jul 19, 2007 | 11:12 AM
RJS91RGTP's Avatar
RJS91RGTP
Default Need help locating part
Hello from Chicago. Saw your post on the door handle bezel. These parts can be found on E-bay for $4-5 each and a little shipping. I had to replace one and told the dealer to take a hike after hearing his price. They are out there, just look.
RJ
Old Jul 19, 2007 | 11:16 AM
F4 Woozzo's Avatar
F4 Woozzo
You want a DOOR PANEL ACCESS COVER PLUG
Look at Corvette Central or Eckler's. I just got 2 at Eckler's, because I just happened to be in Cocoa Beach last week. They were $5 each.
I'm sure most parts houses have them, and they probably are all within a few cents on price.
The online catalogs show photos.
Corvette Central part number 485013
Eckler's part number 44929
They are easily lost because folks getting in the car tend to drag their fingernails along the door panel when they grab the handle. The nail catches the cover and pops it loose. It's happened to me several times, but usually the person recognizes they did it and hand it to me to replace. If they don't notice it will either fall to the ground and be lost, or fall into the car and you'll find it under the seat. Go ahead and buy at least 2, because you'll eventually need them...
Old Jul 19, 2007 | 12:04 PM
Richard Nogen's Avatar
Richard Nogen
Just bought 2 myself cheap on xbay
http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
Old Jul 19, 2007 | 12:47 PM
Robertelarkin
Default Thanks
Thank all of you very much..............I appreciate it.
Old Jul 19, 2007 | 01:01 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I just sat down from a trip to the dealership and picked up three at $3.49/piece. They are notorious for popping out without you noticing them until it is too late.
Micah
Old Jul 19, 2007 | 01:39 PM
Give GMPartsHouse a call - bet they can set you up with the part.
Old Jul 19, 2007 | 06:43 PM
moserbe's Avatar
moserbe
RJ
I just bought a set from that place.
Old Jul 19, 2007 | 06:54 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Hi All,
Thanks for the plug. They are part number 10279471.
Thanks, Gene.
Old Jul 20, 2007 | 07:41 AM
Midwest Vette's Avatar
Midwest Vette
Originally Posted by Gene Culley
Hi All,
Thanks, Gene.
I knew Gene would be able to help.
Old Jul 20, 2007 | 07:56 AM
Robertelarkin
Default Thanks
Thanks for the help............
Old Jul 20, 2007 | 08:20 AM
gpracer1's Avatar
gpracer1
Dealer here has had them in stock for about $5 each.
That stupid red reflector on the door is freakin $36.
Old Jul 20, 2007 | 08:30 AM
Robertelarkin
Default Thanks all
Thank everybody for the help............that's strange, one dealer sells them for $7.00 and mine sells them for $17.00.
I contacted GMPartshouse and they are $3.18/ea, so I ordered 4.........
To Need help to locate a part
