Steering Column Lock Service alert (HELP)
Old Jul 19, 2007 | 07:56 PM
Bakeman31's Avatar
Bakeman31
Default Steering Column Lock Service alert (HELP)
After washing the C5 today, I started the car up and it cut off as soon as I put it into gear. The service alert steering Column lock came on but the car will not move. Did the water, damage something, or is a reset in my future. How can I reset this computer with out towing the car to the service department. Help guys I know this is something simple because the car runs strong.
Old Jul 19, 2007 | 08:09 PM
Cajun99's Avatar
Cajun99
Sorry but it's not a simple issue nor does it have anything to do with how strong your car runs. The column lock problem has been around since 1997 and it ain't going away.
Use your search feature...there are literally dozens and dozens of posts about this issue.
Old Jul 19, 2007 | 08:18 PM
Bakeman31's Avatar
Bakeman31
Thanks, I had a problem with the steering lock a few years ago and had the service done. But I find it funny that it happened after I washed the car.
Old Jul 19, 2007 | 08:19 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Go to the Tech forum and look at the top (all the way up) in the stickies and look for steering column lock and get comfortable 'cause there's much to read. But do yourself a big favour and read about it, write down any questions you may gather and under no circumstances ever let a GM dealership touch your car pertaining to this problem. Their fix has you in the position that you are experiencing right now.
Old Jul 19, 2007 | 08:28 PM
Cajun99's Avatar
Cajun99
Having the recall done to your car is why you're still having the problem. The recall is a joke.
Old Jul 19, 2007 | 08:38 PM
Bakeman31's Avatar
Bakeman31
Thanks fella's, I"m just blown that it starts and runs but as soon as it go's into gear it cuts off. That should be a security issue. Well it's time to read the tech files.
Old Jul 19, 2007 | 08:52 PM
WWK888's Avatar
WWK888
The reason your engine cuts off is because thats they way GM programmed it when they did the recall. If the computer detects a problem with the steering lock (real or perceived) it will cut the fuel at 2mph as a safety feature. You more then likely have a faulty harness which should be covered under the recall. By the way the latest recall came out in Feb 06, so you probably did not have that done. However I would still not have them perform any more recalls and instead purchase the CLB once this problem is resolved.
Old Jul 19, 2007 | 09:14 PM
Bakeman31's Avatar
Bakeman31
Thanks It is the fuel problem, My wheel has not lock on me so I have to find the harnest or change the right fuse. I see this will be an all nighter.
To Steering Column Lock Service alert (HELP)
