2 Codes 0430 and 1571
Old Jul 19, 2007 | 10:43 PM
97BlckCpe's Avatar
97BlckCpe
Default 2 Codes 0430 and 1571
Getting two codes P0430 Cat Effic Low Bank 2 and
P1571 Powertrain Indicated Traction Control Malfunction
What do I need to get to fix the problem
Old Jul 20, 2007 | 06:36 AM
97BlckCpe's Avatar
97BlckCpe
ttt
Old Jul 20, 2007 | 12:06 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I think you're outside the warranty for the cats but you probably need them replaced. Time for hi-flow cats maybe.
Need more info for the traction control malfunction.
Old Jul 20, 2007 | 06:18 PM
M6 Vetter's Avatar
M6 Vetter
Old Jul 20, 2007 | 07:24 PM
97BlckCpe's Avatar
97BlckCpe
I did replace the cats do you think that it can be the O2 sensors? Please tell me yes otherwise the 500 for cats and install is going to send me through the roof
Old Jul 21, 2007 | 05:51 AM
matuszynski's Avatar
matuszynski
it isn't the o2 sensor. if it is, you would have gotten some o2 sensor codes. instead of cat effic code, so it is definitely the cats. get them warranty or put some o2 sims in there. i was able to get a set for under $40.
Old Jul 21, 2007 | 07:20 AM
97BlckCpe's Avatar
97BlckCpe
forgive me for being stupid but what are O2 sims?
Old Jul 21, 2007 | 07:52 AM
trussme's Avatar
trussme
Default Forget 02 "Sims" (simulators)
02 SIMs...."tell" the PCM that everything is OK with exhaust flow thru the Cats... UNFORTUNATELY, the EPA has just mandated their withdrawal from being distributed & sold & installed...or a Fine follows. A tuner with the correct program can tune them (rear 02 sensors) out. Prices range from $100-$200 for this service.
Old Jul 21, 2007 | 08:38 AM
97BlckCpe's Avatar
97BlckCpe
wow welllllllll...ok then that distintictly answers the question. Thanks!
To 2 Codes 0430 and 1571
