brake fluid black
Old Jul 20, 2007 | 12:05 AM
03redzo6's Avatar
03redzo6
Default brake fluid black
hello everyone, i was installing a 160 stat today and i thought i should change my clutch fluid to since it was kind of burned up, i also noticed that my brake fluid is very black and needs to be changed. can i use prestone dot 4 brake fluid and can i use a syringe to take out the fluid or do i need to go another way. thanks
Old Jul 20, 2007 | 06:25 AM
If your fluid is that black, I'd probably go ahead and get the entire brake system flushed. I'm going to have mine done next Tuesday.
Old Jul 20, 2007 | 06:47 AM
Lancer033's Avatar
Lancer033
DOT 3 and DOT 4 mix no problem
the syringe will work, but won't get the fluid in the lines are calipers, so it's not a full solution. Like JD said, you need to bleed the system
Old Jul 20, 2007 | 07:00 AM
Bob CTS's Avatar
Bob CTS
Go ahead and flush the brake fluid, just bleed every wheel until it comes out clean.
Old Jul 20, 2007 | 07:08 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
buy yourself the Motive Pressure Bleeder. It is easy to use.
Take the old brake fluid out of the reservoir.
Add new brake fluid.
Attach the pressure bleeder to the reservoir
pressurize the bleeder to 12-15 lbs.
open your bleeder valve and wait for the new fluid to come through
Just make sre you dont run out of fluid in the reservoir.
It is very easy to use and a 1 person job.
Old Jul 20, 2007 | 07:13 AM
Midwest Vette's Avatar
Midwest Vette
They do work great.
Old Jul 20, 2007 | 08:58 AM
Autoworker's Avatar
Autoworker
Another solution would be to install Speedbleeders on each caliper. They have a checkball built in them, you open the bleeder 1/2 turn and bleed that caliper. I also used Motorcraft high performance brake fluid. Supposed to be one of the higher boiling point fluids.
Old Jul 20, 2007 | 09:09 AM
Secret237's Avatar
Secret237
Just make sure you dont run out of fluid in the reservoir.
That is exactly what I do. I use 2 quarts of fluid, I use Castrol GT LMA (Low Moisture Absorbtion) but many here use Valvoline synthectic.
Yes makes bleeding your brakes a one person job, no need for "help" from the wife.
Old Jul 20, 2007 | 09:10 AM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
You could use the syringe, I did mine that way as my brake fluid was dark also. You need to do it at least one a week until the fluid is clear. Mine took 3 times and it's nice and clear.
Old Jul 20, 2007 | 10:19 AM
csexton's Avatar
csexton
They work great
Chuck
Old Jul 20, 2007 | 10:39 AM
z06Bigbird's Avatar
z06Bigbird
Heck, it took me 40 years to train my wife on this; and, now, you tell me that she is "not needed." Are you crazy, man!!
z06Bigbird's Avatar
z06Bigbird
How many $$ for that special tool?
Old Jul 20, 2007 | 11:18 AM
Wicked Weasel
www.motiveproducts.com
GM bleeder is around $55.00
Old Jul 20, 2007 | 12:31 PM
rws.1's Avatar
rws.1
www.speedbleeder.com
Old Jul 21, 2007 | 02:03 PM
PugLover's Avatar
PugLover
Default Did the syringe method
After reading this post I looked at my brake fluid and it was DARK black so I went and bought a synringe from Advanced auto and it worked awesome. Thanks for the info.
Mark
Old Jul 21, 2007 | 08:59 PM
FAAASTJEDI2000's Avatar
FAAASTJEDI2000
needs to be replaced.
To brake fluid black
