Push Pin Removal
Old Jul 21, 2007 | 12:30 PM
foundvettelifeisgood's Avatar
Default Push Pin Removal
What are the ways to remove the push pins at the base of the rear fascia without hurting them?
Thanks.
Old Jul 22, 2007 | 01:35 AM
$hawn's Avatar
$hawn
Squirt some wd-40 on them and a small flat blade screw driver.
Old Jul 22, 2007 | 03:58 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I prefer lifting a little with a small flat head and then needle nose pliers
Old Jul 22, 2007 | 11:38 PM
A pair of side cutters carefully used will usually work too.
Old Jul 23, 2007 | 12:09 AM
Mike Mercury's Avatar
Mike Mercury
I use a door panel removal tool. Kinda like this one:
Old Jul 23, 2007 | 12:11 AM
C5naples's Avatar
C5naples
That is exactly what I use
Old Jun 6, 2009 | 05:31 PM
98whitevette's Avatar
98whitevette
Default Help!
I am struggling with removing push pins from the front fascia...I squirted wd40 and am using a flat head screw drive and a plier; they partially lift from the bottom but aren't coming out...am I doing something wrong. I have almost wrecked one of the push pins in the process and damaged teh paint underneath. I am sure this can't be such a hard step.. PLEASE HELP!
Old Jun 6, 2009 | 05:47 PM
Buy the right tool. See the driver pictured in this thread. It's cheap and at every parts place.
To Push Pin Removal
