I believe their is one someone told me about it a few years ago i went to the web sight but you had to pay to belong to it so i did not join.I don't know if it still is around or not........Charlene
Originally Posted by Janster
Nice!!
You go girl!!
Hey Ladies - dumb question - but is there a womens only corvette forum somewhere? Just curious....
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Originally Posted by The Wanderer
Kind of watching this back in the early days of TV
In case the youngsters don't know:
Probably the most famous American B&W test pattern is the so-called "Indian Head" monoscope pattern. This pattern was originated by RCA in 1939; it was designed to be generated using a special tube called a monoscope, a CRT which had a metal plate target on which the pattern was printed. The black lines of the pattern would interrupt current flow as the pattern was scanned to provide the desired video output. These tubes could only handle black and white - no shades of gray hence they had to be simulated either with a halftone dot pattern or with patterns of fine lines.
Just run a diagnostic on your DIC, copy the codes and get back to us and we will try to help you. Without codes we're a bit lost.
I registered there a couple months ago. I e-mailed to request a login & password .....But...I haven't seen nor heard of them doing anything & I haven't seen any updates on the site since I registered.
I feel bad - cuz I know how much work it takes to do that kinds stuff and I think there's only one lady doing all the work. I e-mailed and offered to help, even at Carlisle. So I'm just *standing by* waiting for her to contact me to help her out.
From: "Never play games with a bitch who can play them better" NE PA
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
I just did that a little while ago. If you hear anything or need any help---let me know--I'm more than happy to lend a hand.
