leaky passenger window
Old Jul 24, 2007 | 09:52 AM
Warnberg
Guest
Posts: n/a
Default leaky passenger window
I've been looking for any info on how to fix a leaky passenger window. I found after coming back from EG's in heavy rain that my passenger window leaks toward the rear of the window. The water seems to be coming from the last (rear) hole in the weather stripping.
Do I just need to get some of this stuff (GM Weather Strip Adhesive Gel-Black 2 fl. oz tube, P/N 12345096) to help seal it?
Any help appreciated.
Dave
Old Jul 24, 2007 | 10:19 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Is it the window or the roof? Just asking, because if you have a coupe, it is a common problem in the corners.
Old Jul 24, 2007 | 10:26 AM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
I got the same issue on both windows, back of the passenger side towards to front on the driver side.
Old Jul 24, 2007 | 11:06 AM
Bluefire's Avatar
Bluefire
I had the same problems with mine. It turns out that I accidently pinched the weatherstriping in the rear corners the last time I put the roof back on. Thankfully, It wasn't like that long enough to permanently deform the weatherstriping.
Old Jul 24, 2007 | 11:20 AM
Warnberg
Guest
Posts: n/a
It's a coupe, looks to me like it's the weather stripping on the top that is leaking...
If you look at the weatherstripping along the side of the top you will see there are several little holes in it (inside the car next to the window) the water was coming out of the rear hole. As long as I was moving at a decent clip it would not leak.
Thanks,
Dave
Old Jul 26, 2007 | 11:08 AM
Warnberg
Guest
Posts: n/a
Well I think I found the issue... anyone know where I can get some new weather stripping? Looking for the rear piece, the one that runs vertically up and down on the rear post.
Dave
Old Jul 26, 2007 | 12:59 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I believe I seen some on Ecklers. I don't know if that is the best price though.
Old Jul 26, 2007 | 02:59 PM
zeus79's Avatar
zeus79
Veteran: Marine Corps
If its not the weather stripping it might be the window adjuster. Just had mine adjusted today to make a better seal with the weather stripping.
Old Jul 26, 2007 | 03:21 PM
csexton's Avatar
csexton
Dave,
If you need to adjust the window this site will be useful
Chuck
https://www.corvetteforum.com/forums/C:\Corvette\Side Window Tip In Adjustment.htm
Old Jul 26, 2007 | 09:22 PM
If you need to replace the weatherstripping, try GMPartsHouse and check out their prices.
Old Jul 26, 2007 | 09:32 PM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Originally Posted by csexton
Dave,
Chuck
Chuck the link you put in the post no workie.... It's to your local drive on your system....
Old Jul 26, 2007 | 11:50 PM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
I think my windows just need adjust a tick higher, so hopefully someone gets that link up.
To leaky passenger window
