Main Computer Location ?
Old Jul 26, 2007 | 12:47 PM
Robertelarkin's Avatar
Robertelarkin
Default Main Computer Location ?
I heard that the main computer was located under the battery..........is this correct. If this is so what would be the best way to access it.
Also, what is the unit that is in the rear, left storage bin ?
Robert
Old Jul 26, 2007 | 01:07 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
yes, its under the battery. the best way to get to is is from the passenger inner wheel well. take off the wheel and theres a panel that unscrews to access it.
Old Jul 26, 2007 | 01:09 PM
LoneStarFRC's Avatar
LoneStarFRC
You'll need a 7mm socket for the screws.
Old Jul 26, 2007 | 01:13 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Robert
I think maybe the BCM?
Old Jul 26, 2007 | 01:17 PM
LoneStarFRC
Not the BCM, it's located under a removable panel in the passenger side footwell.
Robertelarkin: Are you the original owner? If not maybe the previous owner installed an amp or something?
Old Jul 26, 2007 | 01:22 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Ah ya thats right, I knew that too..
Ive got a silver box in the driver side storage compartment too. (coupe)
Old Jul 26, 2007 | 02:07 PM
kromberg's Avatar
kromberg
BCM and PCM are located in the same area.
Keith
Old Jul 26, 2007 | 02:09 PM
Robertelarkin
No, I just picked up this 2003 AE vert with 8300 miles, on it. I am not having any problems at all............just curious about the computer location.........I remember I got caught in one of those afternoon SHOWERS in Houston a few years ago, I was in my C4 and the water was almost to the top of my tires, I thought I was driving a submarine. I was hoping the computer did not get wet..........there was nowhere to go but keep driving. It was getting-off work traffic..........the only thing I could do was to floor it and keep driving, luckily I got to higher ground.
Robert
Old Jul 26, 2007 | 02:12 PM
vettejeff's Avatar
vettejeff
I think the computer box in the rear is for the magnetic shocks, or adjustable suspension.
Old Jul 26, 2007 | 02:19 PM
Robertelarkin
I was curious what that box was.................I wonder if it is very delicate...........I would not want to store something in that bin that would harm or hit that box in any kind of way.
Robert
Old Jul 26, 2007 | 04:03 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Robert
Here is a cut away picture of PCM.
Old Jul 26, 2007 | 04:12 PM
Robertelarkin
Default Thanks
Thank you..........that is a cool shot..............
Old Jul 26, 2007 | 04:17 PM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
On my '04 with F55 Magnetic Selective Ride suspension, the unit in the left rear well is the F55 control computer. I don't know whether the '03s had the F55 option available, but if they did, and you have the selective ride control switch down on the center console, that's your answer.
Robertelarkin
Default Computer Location
Now I am wondering how water tite this location...........I guess the engineers thought this out and know best..........sure looks like a better, higher location could be found.
I was scared when my C4 was wheel-deep in a flash flood and its computer is on top of of the engine.......above the battery..........go figure.
Old Jul 26, 2007 | 04:48 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
The box is a one piece design and the bottom connectors have rubber seals on them. The harness connectors are screwed into the PCM.
Old Jul 26, 2007 | 05:59 PM
Old Jul 26, 2007 | 06:16 PM
Jet-Jock's Avatar
Jet-Jock
Interesting kewl picture. I believe we are also seeing half the fuel cell where the rear panel is removed; half on one side half on the other.
To Main Computer Location ?
Old Jul 27, 2007 | 08:05 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You're looking at the trunk (Aka rear floor) not the fuel cells. The fuel tanks are behind the seats in a C5.
Here's a better shot of PCM mounting bracket.
Old Jul 27, 2007 | 08:11 AM
Jet-Jock's Avatar
Jet-Jock
Thanks for the correction. They are split into two tanks correct?
Old Jul 27, 2007 | 08:12 AM
Robertelarkin
Default Thanks
Thanks a lot.............those are very good, detailed photos.
